Anyone ever try this cosmoline on lower control arms?? #2648855
04/25/19 01:10 PM
04/25/19 01:10 PM
Far Northeast.
mymcodebee Offline OP
Far Northeast.
I had a can from Eastwood’s years but it’s gone now. Anyone try this?? Wondering if color is correct?
Re: Anyone ever try this cosmoline on lower control arms?? [Re: mymcodebee] #2648964
04/25/19 06:15 PM
04/25/19 06:15 PM
WV
Little Detroit Offline
WV
its not a paint , its a coating to keep bare metal and machined parts "temporally " rust free . great for spraying on machined surfaces such as blocks, cylinder heads . the Military uses it for packing fire arms and other things when being shipped overseas to protect from saltwater corrosion.
Re: Anyone ever try this cosmoline on lower control arms?? [Re: mymcodebee] #2648977
04/25/19 06:43 PM
04/25/19 06:43 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I don't know about 'correct', but it looks very close to me. I used it on my 71 GTX that got OE Certified. But as mentioned, it is not a paint. It takes a day or two to dry and ends up kinda waxy on the surface and will not wear well. But if you want it to look correct, that is the price you pay.
Master, again and still
Re: Anyone ever try this cosmoline on lower control arms?? [Re: DaveRS23] #2648993
04/25/19 07:55 PM
04/25/19 07:55 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
That is manufactured by the same company that makes the original Cosmoline, they sell variations of the same stuff in various containers. I used a 5-gallon bucket of it (expensive) to dip parts in as they were at the factory. The spray is likely a thinned version of the same stuff but will likely yield a different look if sprayed on. Won't hurt to try.
Re: Anyone ever try this cosmoline on lower control arms?? [Re: ScottSmith_Harms] #2649000
04/25/19 08:06 PM
04/25/19 08:06 PM
SE PA
cudaize Offline
cudaize  Offline
SE PA
The A2 is a clear. I have been using this to preserve many of the bare metal parts on my car. The spray can version is really thin, smells to be thinned with xylene, I have talked to some folks that buy it in quarts/gallons and thin it with mineral spirits and shoot out of a cleaning solution sprayer like a fantastik bottle.
Re: Anyone ever try this cosmoline on lower control arms?? [Re: ScottSmith_Harms] #2649015
04/25/19 08:39 PM
04/25/19 08:39 PM
Far Northeast.
Far Northeast.
Excellent. May give it a try. The Eastwood stuff was also s cosmoline type material that never really dried.
Just trying to save buying a 5 gallon pail which by far looks the best!
Thanks guys!
Re: Anyone ever try this cosmoline on lower control arms?? [Re: ScottSmith_Harms] #2649043
04/25/19 09:15 PM
04/25/19 09:15 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
When I did mine (it's been 20 years ago), it took several coats to get the look right. And it took a day or two for each coat to dry. But in the end, it looked good. twocents
Re: Anyone ever try this cosmoline on lower control arms?? [Re: mymcodebee] #2649208
04/26/19 10:12 AM
04/26/19 10:12 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Thanks guys!
Cosmoline never really dries. It is a coating not a paint. I shoot matte clear over it after it cures to keep it from being sticky.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Anyone ever try this cosmoline on lower control arms?? [Re: MOPARMIKE69] #2649221
04/26/19 10:47 AM
04/26/19 10:47 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
I had bought the smaller quantity of Cosmoline to do my lower control arms. First I blasted them clean, and then used RPM on them, THEN the cosmoline, hoping that when the cosmoline came off, no rust would appear . . . and here it is about 5k miles later . . .
Re: Anyone ever try this cosmoline on lower control arms?? [Re: a12rag] #2649480
04/27/19 08:00 AM
04/27/19 08:00 AM
Akron, ohio
76orangewagon Offline
Akron, ohio
I used Krylon Battery protector, not a Cosmoline but I was happy with the results after several coats, I hung them and sprayed heavy to purposely get the runs of a dipped part. Sorry...its not what you were asking about in your original post, but just wanted to share another possible option.
Re: Anyone ever try this cosmoline on lower control arms?? [Re: 76orangewagon] #2649601
04/27/19 05:30 PM
04/27/19 05:30 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
I used this and I think it worked very well twocents
Re: Anyone ever try this cosmoline on lower control arms?? [Re: 5carguy] #2649655
04/27/19 08:23 PM
04/27/19 08:23 PM
Far Northeast.
Far Northeast.
I almost think the stuff I got from Eastwood’s was a battery type product! I used it on many cars. I forgot thats what it was till you guys just mentioned that!
