Re: mechanical fuel inj. nozzles
[Re: merpar]
#2648604
04/24/19 08:30 PM
04/24/19 08:30 PM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
Its not that simple...for clean out just run it til it stumbles then your good. Define "run it on race gas"? just for clean out?
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: merpar]
#2648839
04/25/19 12:46 PM
04/25/19 12:46 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
Does the top end lube for alcohol stop the crystals forming? If so are you using it?
[Re: merpar]
#2648953
04/25/19 05:34 PM
04/25/19 05:34 PM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
to answer your question 8ea .028 nozzles are .004926 sq inches 8 ea .020 nozzles are .002513 sq inches 8 ea .019 nozzles are .002268 sq inches
Joe
Without Data, you’re just another guy with an opinion.
[Re: merpar]
#2649272
04/26/19 12:46 PM
04/26/19 12:46 PM
Posts: 588 Franklin, TN
23T Hemmee
Franklin, TN
Assuming you've got a 3-way mechanical fuel shut-off, start it and immediately start pulling back on the shut-off slowly bypassing fuel back to the tank. Idle will increase and temp will too, so don't pull back too far, but 15-20 seconds or so should clean out most gunk buildup, Definitely a trial and error method, better to lean too slowly than too quickly.
BTW the crystals form in old alky, top lube won't help there
Re: Milodon
[Re: 19581021 7132]
#2667184
06/18/19 01:07 PM
06/18/19 01:07 PM
23T Hemmee
Franklin, TN
No, sorry, sold the last sleeve, stud, etc. everything I could salvage to a member on here, Oyvind Mopar, several years ago. Havn't seen him post in a long time, don't know if he ever got it together or not, or if he is still on here.
