Re: shift point
[Re: dragon]
#2647476
04/21/19 08:12 AM
04/21/19 08:12 AM
Posts: 4,208 New York
polyspheric
New York
and it will be different 1-2 from 2-3
Boffin Emeritus
Re: shift point
[Re: Cab_Burge]
#2647497
04/21/19 10:02 AM
04/21/19 10:02 AM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
I use to think that a engine dyno sheet would really help me to start with a shift RPM at or near peak HP RPM, NOT SO on every motor is what I found out You can try shifting at peak HP RPM for several passes and then try short shifting it by 200 to 500 RPM below that, if it goes slower try 200 to 500 RPM above the peak HP RPM and it goes quicker and faster keep testing until you find out what your car really likes The converter and several other things determine what shift points will work the best for each car Most theory on drag racing are just that, theories That's the beauty of drag racing...there are no canned answers. Performance is elusive you have to work for it!
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: shift point
[Re: polyspheric]
#2647520
04/21/19 11:06 AM
04/21/19 11:06 AM
Posts: 4,316 Prospect, PA
BSB67
Prospect, PA
and it will be different 1-2 from 2-3 When people ask me where I shift, I ask them: which gear change? People are usually astonished where I shift at. But I think my stuff is so fundamentally different than what the race guys do, there is no point in comparing. The world of 106° LSAs with 102° ICL is sooo different than 112° + LSAs and >112° ICLs, not to mention a converter that is tight at 2200 rpm.
Re: shift point
[Re: Dave Hall]
#2649757
04/28/19 08:08 AM
04/28/19 08:08 AM
Posts: 16,928 NC
440Jim
NC
The accepted start point is to have the engine pull down to peak torque after the shift. If this is a typical Mopar with a big, straight, bada$$ torque line, the car may like high gear ASAP. I like this starting point. And it reflects what Cab said about the converter effect on shift point. My converter guy said the converter should pull the engine down to max torque at the shift, assuming a certain RPM drop.
Re: shift point
[Re: 440Jim]
#2649769
04/28/19 08:26 AM
04/28/19 08:26 AM
Posts: 9,847 MI, usa
dvw
MI, usa
A few things I've learned. Shifting earlier than needed on a high torque engine seldom bothers ET much. Shifting late will slow you down. 727 trans takes a few hundred RPM to complete the shift. In testing Turbo Action valvebodys in my stuff it can be 300-600 RPM depending on if its 1/2 or 2/3. The RPM doesn't fall as far on the 2/3 as it does on 1/2. Therefore the 2/3 can be later. If you want to be consistent the shift needs to be close to correct every time. Not using a tach isn't going to get it. We try to predict runs within .005 or closer. Ultimately the quickest acceleration will be measured by highest average G force. For those of you that are running data loggers and that fancy stuff. Read here: https://www.racepagesdigital.com/tech-why-the-g-meter-is-the-most-important-sensor-for-going-fast/Doug
Re: shift point
[Re: John_T_Brown]
#2649947
04/28/19 04:26 PM
04/28/19 04:26 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
My Go Pro showed me I short shift when I leave first and bounce off the rev limiter when I'm chasing. Probably a hold over from my motocross days, but I don't see the shift light even though it's in my face.
Anyway....Hello Shifnoid.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
Re: shift point
[Re: Adobedude]
#2649954
04/28/19 04:54 PM
04/28/19 04:54 PM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The way I look at it is....... it comes down to the interaction between the motor and converter.
Swapping from a 2800 stall converter to a 4800 stall converter will almost certainly require a different shift point for best ET’s.
You just need to experiment some and see what works best in your combo.
