shift point #2647229
04/20/19 12:43 PM
04/20/19 12:43 PM
ohio
dragon Offline OP
dragon  Offline OP
ohio
How are you figuring you shift point from your dyno sheet. Thanks
Re: shift point [Re: dragon] #2647250
04/20/19 01:38 PM
04/20/19 01:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Your gonna have to play with that but its usually just above the
max torque point but it varies
wave
Re: shift point [Re: MR_P_BODY] #2647302
04/20/19 04:12 PM
04/20/19 04:12 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
I shift at my max HP.
NOT your torque.
You'll be shifting way too early going by peak torque.
Re: shift point [Re: dragon] #2647381
04/20/19 08:35 PM
04/20/19 08:35 PM
I use to think that a engine dyno sheet would really help me to start with a shift RPM at or near peak HP RPM, NOT SO tsk on every motor is what I found out confused
You can try shifting at peak HP RPM for several passes and then try short shifting it by 200 to 500 RPM below that, if it goes slower try 200 to 500 RPM above the peak HP RPM and it goes quicker and faster keep testing until you find out what your car really likes up wrench
The converter and several other things determine what shift points will work the best for each car shruggy
Most theory on drag racing are just that, theories whiney
Re: shift point [Re: dragon] #2647391
04/20/19 08:52 PM
04/20/19 08:52 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
The accepted start point is to have the engine pull down to peak torque after the shift. If this is a typical Mopar with a big, straight, bada$$ torque line, the car may like high gear ASAP. shruggy
Re: shift point [Re: Dave Hall] #2647441
04/21/19 01:06 AM
04/21/19 01:06 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I shift when it feels right. Ron
Re: shift point [Re: dragon] #2647476
04/21/19 08:12 AM
04/21/19 08:12 AM
New York
polyspheric Offline
polyspheric  Offline
New York
and it will be different 1-2 from 2-3
Boffin Emeritus
Re: shift point [Re: Cab_Burge] #2647497
04/21/19 10:02 AM
04/21/19 10:02 AM
Byron, NY
W.I.N. Racing Offline
Byron, NY
iagree
That's the beauty of drag racing...there are no canned answers. Performance is elusive you have to work for it!
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: shift point [Re: W.I.N. Racing] #2647509
04/21/19 10:25 AM
04/21/19 10:25 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Time slips don't lie.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: shift point [Re: polyspheric] #2647520
04/21/19 11:06 AM
04/21/19 11:06 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
When people ask me where I shift, I ask them: which gear change? People are usually astonished where I shift at. But I think my stuff is so fundamentally different than what the race guys do, there is no point in comparing. The world of 106° LSAs with 102° ICL is sooo different than 112° + LSAs and >112° ICLs, not to mention a converter that is tight at 2200 rpm.
Re: shift point [Re: BSB67] #2649686
04/27/19 09:49 PM
04/27/19 09:49 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I went racing this week and I can tell you I did not look at the tach at all going down the track and never do. I just shift when I feel it peaking. I ran 10.76 three passes in a row a few years ago so I must be getting the shift points pretty close. And I almost always run within a few hundredths all day unless something goes wrong. I know using the tach can keep you consisdent but I always shift any car I drive by when I feel the eng is peaking and I have always been as fast or faster in any car I have raced then anyone else who drives them. Ron
Re: shift point [Re: Dave Hall] #2649757
04/28/19 08:08 AM
04/28/19 08:08 AM
NC
440Jim Offline
440Jim  Offline
NC
I like this starting point. And it reflects what Cab said about the converter effect on shift point.
My converter guy said the converter should pull the engine down to max torque at the shift, assuming a certain RPM drop.
Re: shift point [Re: 440Jim] #2649769
04/28/19 08:26 AM
04/28/19 08:26 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
A few things I've learned. Shifting earlier than needed on a high torque engine seldom bothers ET much. Shifting late will slow you down. 727 trans takes a few hundred RPM to complete the shift. In testing Turbo Action valvebodys in my stuff it can be 300-600 RPM depending on if its 1/2 or 2/3. The RPM doesn't fall as far on the 2/3 as it does on 1/2. Therefore the 2/3 can be later. If you want to be consistent the shift needs to be close to correct every time. Not using a tach isn't going to get it. We try to predict runs within .005 or closer. Ultimately the quickest acceleration will be measured by highest average G force. For those of you that are running data loggers and that fancy stuff. Read here:
https://www.racepagesdigital.com/tech-why-the-g-meter-is-the-most-important-sensor-for-going-fast/
Doug
Re: shift point [Re: dvw] #2649812
04/28/19 10:22 AM
04/28/19 10:22 AM
Sterling Heights, MI
John_T_Brown Offline
Yep, been doing it that way for 25 years give or take a couple. Data is your friend... not your butt. grin
Data Recorder
If it ain't broke fix it anyway!
Re: shift point [Re: John_T_Brown] #2649947
04/28/19 04:26 PM
04/28/19 04:26 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
My Go Pro showed me I short shift when I leave first and bounce off the rev limiter when I'm chasing.
Probably a hold over from my motocross days, but I don't see the shift light even though it's in my face.
Anyway....Hello Shifnoid.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: shift point [Re: Adobedude] #2649954
04/28/19 04:54 PM
04/28/19 04:54 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The way I look at it is....... it comes down to the interaction between the motor and converter.
Swapping from a 2800 stall converter to a 4800 stall converter will almost certainly require a different shift point for best ET’s.
You just need to experiment some and see what works best in your combo.
