Re: 727 question [Re: dodgefarmer] #2645591
04/16/19 01:52 AM
04/16/19 01:52 AM
Chicago adjacent
WS68SSC Offline OP
Newest
WS68SSC  Offline OP
Newest
Chicago adjacent
There is alot of slop between the servo piston and the adjustment arm (rear). Could the piston be stuck?
Re: 727 question [Re: WS68SSC] #2645651
04/16/19 09:09 AM
04/16/19 09:09 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
If it is stuck it can cause the reverse problem but not the third gear problem. Also would have no eng braking in low gear but it sounds like you have more then just a low/reverse servo problem. I agree it needs to come out. Ron
Re: 727 question [Re: 383man] #2645684
04/16/19 11:29 AM
04/16/19 11:29 AM
Chicago adjacent
WS68SSC Offline OP
Newest
WS68SSC  Offline OP
Newest
Chicago adjacent
Re: 727 question [Re: WS68SSC] #2645686
04/16/19 11:30 AM
04/16/19 11:30 AM
Chicago adjacent
WS68SSC Offline OP
Newest
WS68SSC  Offline OP
Newest
Chicago adjacent
Re: 727 question [Re: WS68SSC] #2645689
04/16/19 12:01 PM
04/16/19 12:01 PM
The Sunny Shuswap
dodgefarmer Offline
dodgefarmer  Offline
The Sunny Shuswap
In the pics it looks more or less normal. You could try a band adjust to see if it makes any diff. Back off the lock nut (without moving the adjusting screw). Tighten adjusting screw, count the turns til contact with servo, then back adjusting screw out 2 1/4 turn. Tighten the lock nut (without moving the adjusting screw) I don't think it will make a diff. but you won't know if you don't try.
Good luck.
Re: 727 question [Re: WS68SSC] #2645705
04/16/19 01:23 PM
04/16/19 01:23 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Looks close to correct That's why you back it off after snuggingtbe adjustment but. 5/16" give or take . You can air check both servos.
Doug
