340 Column Shift Linkage Help Needed #2641935
04/06/19 12:04 PM
04/06/19 12:04 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Anyone have a pic or illustration of an A-Body 340/727 column shift setup (Z-Bar)? This is the bracketry/hardware that goes from the shift lever to the steering column.
Re: 340 Column Shift Linkage Help Needed [Re: vinnyd76] #2641958
04/06/19 12:58 PM
04/06/19 12:58 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: 340 Column Shift Linkage Help Needed [Re: Alaskan_TA] #2642618
04/08/19 09:02 AM
04/08/19 09:02 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Originally Posted by Alaskan_TA
Thank you for the diagram! Attached is the illustrations that you provided with some comments on the issues that I'm experiencing. Any assistance would be greatly appreciated.
Re: 340 Column Shift Linkage Help Needed [Re: vinnyd76] #2642768
04/08/19 02:29 PM
04/08/19 02:29 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
I'm pretty sure brackets are different for 727/904. Not sure of which pieces or what years may cause a conflict. My guess is that you may see a change if the bracket on the column changed, which could change the "throw."
Re: 340 Column Shift Linkage Help Needed [Re: Montclaire] #2642773
04/08/19 02:34 PM
04/08/19 02:34 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
904 and 727 parts are different for several of those pieces.
Re: 340 Column Shift Linkage Help Needed [Re: Neil] #2642898
04/08/19 06:48 PM
04/08/19 06:48 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
The bracket on the trans is different between 904 and 727..its longer..the frame side should be the same
Re: 340 Column Shift Linkage Help Needed [Re: AARCONV] #2643430
04/09/19 09:19 PM
04/09/19 09:19 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Anyone have a pic of their A-Body shift linkage that they can share with a 340/727/column shift setup?
Re: 340 Column Shift Linkage Help Needed [Re: vinnyd76] #2643433
04/09/19 09:23 PM
04/09/19 09:23 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I have pictures of my linkage. I can also take pics of my car. My pictures are on my other computer and I probably won't be able to get to it until tomorrow. What do you want to see? Send my a PM with your email.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: 340 Column Shift Linkage Help Needed [Re: FJR doc] #2643936
04/11/19 08:07 AM
04/11/19 08:07 AM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I couldn't find pictures of my linkage off of the car. Here are some pics of it installed.
Kevin
Re: 340 Column Shift Linkage Help Needed [Re: FJR doc] #2643950
04/11/19 09:08 AM
04/11/19 09:08 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Mine is also tight as mentioned by the OP on both the 72 Duster and the 69 Dart...
In looking at the above pics the bracket in the first picture that bolts to the trans is different than mine...
Mine does not have the offset which relocates it forward...
I suspect that may be the same problem the OP is having...
Both my cars were /6 cars with 904's and the crossbars and all linkage and brackets from the slant six cars were re-used when the 340's went in...
It can be made to operate fine but it is tight... twocents
I searched all my pics but had none of that linkage... shruggy
...FAFO...
Re: 340 Column Shift Linkage Help Needed [Re: skicker] #2647810
04/22/19 12:29 PM
04/22/19 12:29 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Thank you very much for the pics and feedback. The restoration shop is having an issue with the shifting into low (1-gear). I'm going to share the pics/info with them. I cannot believe how tight area is to fit all the linkage. The technicians/mechanics have/had to have patience when working on these A-Bodies.
