Rocker Advice #2643445
04/09/19 09:46 PM
04/09/19 09:46 PM
Kansas, US
brianlinn Offline OP
Kansas, US
Apologies for asking a question that has been asked time and time again... I’m building a full roller 440, 10.5:1, Edelbrock Performer Heads, Edelbrock Performer intake, Demon 850 carb, Howard’s Roller cam (278 283 duration .531 .547, .230 .236 @ 50 with 1.5 rockers). I’m looking for 1.6 roller rockers and curious which is better as far as Jesel , Harland Sharp, T&D etc... This is just a little street/strip car. Looking for quality, durability and longevity. I appreciate any and all thoughts. Thanks!
Re: Rocker Advice [Re: brianlinn] #2643448
04/09/19 09:59 PM
04/09/19 09:59 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
Can't answer your question as I don't have any experience with the rocker arms you've mentioned but, I hear Rocker Arms Unlimited (previously RAS) is making their rocker arms again. Many people have praised them. Something to maybe look in to.
Re: Rocker Advice [Re: brianlinn] #2643452
04/09/19 10:09 PM
04/09/19 10:09 PM
Get-X Offline
Get-X  Offline
The Harlan Sharps and T&D are both excellent rockers. If I had to choose between them I'd use the T&Ds. I wasn't aware that Jesel was making a shaft rocker kit for that combo?
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: Rocker Advice [Re: Get-X] #2643455
04/09/19 10:23 PM
04/09/19 10:23 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
If it was me for that combo I would go with Harland Sharp rockers and I would be on the look out for a 10% off coupon for Summit.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Rocker Advice [Re: brianlinn] #2643459
04/09/19 10:35 PM
04/09/19 10:35 PM
AndyF Offline
AndyF  Offline
T&D makes the best shaft rocker for that application but they are expensive. Jesel rockers are even better but would require machine shop work. I don't think I'd spend the money for Jesel rocker arms until 0.800 lift. You are under 0.600 lift which means that most any rocker arm will work. The Mancini rocker arms would work okay with that cam and save you a bunch of money.
Re: Rocker Advice [Re: AndyF] #2643461
04/09/19 10:52 PM
04/09/19 10:52 PM
Washington
skrews Offline
skrews  Offline
Washington
I'd go HS.
Re: Rocker Advice [Re: AndyF] #2643462
04/09/19 10:53 PM
04/09/19 10:53 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I like Harland Sharps a bunch for something like this.
I have used them on a three different motors and never had an issue.
I have T&D's on my current deal , but only because Sharps aren't made for the W-9's.
I looked at Jesel , but they were more $$ for what I wanted and T&D's quality is top notch.
Re: Rocker Advice [Re: tubtar] #2643471
04/09/19 11:22 PM
04/09/19 11:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
All I run on my engines is TD rockers.. thats on my B1MC to my SB
stuff.. never had a failure
wave
Re: Rocker Advice [Re: brianlinn] #2643475
04/09/19 11:36 PM
04/09/19 11:36 PM
I've used all kinds of different brand and material type rocker arms on BB Mopar motors for drag racing and street use.
I have found a bunch of variance on lift at the retainers on all of them including the T&D single shaft, on your deal I would go with the full roller Harland Sharps, not the newer cheaper extruded aluminum street sets tsk
Call them and talk to Steve and tell him exactly what ratio you want so they can build them that way, there standard off the shelf set of 1.6 ratio will usually measure at the retainers with checking springs to be 1.65 or so shruggy
I had them make me a new set for a set of Indy 440-1 heads and told him I wanted between 1.57 to no more than 1.60 ratio three months ago and they ended up checking out to be 1.59 ratio at the retainers up
I will be building a new semi all out BB Mopar 555 C.I. drag race motor in the next year or so for myself that will have a set of B1-MC heads with a set of custom made steel T&D pair shaft rocker arm set up for those heads, not cheap or quick but quality never is work
Re: Rocker Advice [Re: brianlinn] #2643490
04/10/19 01:33 AM
04/10/19 01:33 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
After having issues with other rockers, both my friends 470" stroker with RPM heads, and my 505" stroker with stealth heads are running Harlan Sharpe rockers with Smith brothers pushrods, and have not had any problems.
Not sure why the price of good rocker arms has jumped so much in the last few years? The S70016K 1.6:1 ratio set is now $830. About 5-6 years ago they were only $550-$600 a set.
Not sure how much the T&D rockers cost now. I have their max wedge victor rockers and they are good parts too.
Re: Rocker Advice [Re: parksr5] #2643493
04/10/19 02:06 AM
04/10/19 02:06 AM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
Ran those on my NHRA stocker engines, Great product,
Real Men shift for themselves
Re: Rocker Advice [Re: brianlinn] #2643589
04/10/19 10:31 AM
04/10/19 10:31 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Go with the HS, work fine good quality...
Just my $0.02.... wink
Re: Rocker Advice [Re: pittsburghracer] #2643621
04/10/19 11:27 AM
04/10/19 11:27 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
iagree
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Rocker Advice [Re: an8sec70cuda] #2643667
04/10/19 01:30 PM
04/10/19 01:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've had too many problems with the HS rockers.. the length tended
to vary to much so thats when I changed to the TD ones
wave
Re: Rocker Advice [Re: MR_P_BODY] #2643676
04/10/19 02:01 PM
04/10/19 02:01 PM
PA.
"Little"John
"Little"John
PA.
I called Harlan Sharp and asked if they could make me 8 small block Mopar rockers with a .350 intake offset for a set of Edelbrock heads I’m playing with. He quoted me a very fair price and I had them less than 10 days later.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Rocker Advice [Re: pittsburghracer] #2643681
04/10/19 02:14 PM
04/10/19 02:14 PM
HS made us a custom offset set of shaft mount rockers for the SB Chevy in the Camaro. Nice stuff and great service...everyone thinks they're T&D rockers when we have the covers off b/c they aren't the typical gold/amber HS color.
CHIP
Re: Rocker Advice [Re: pittsburghracer] #2643684
04/10/19 02:15 PM
04/10/19 02:15 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Look at the difference in price between T&D an Harland Sharp. I bet they are within $100.00 dollars of each other. T&D is a superior product in my opinion. Do yourself a favor and get cup adjusters and go ball-ball pushods (No more burned pushrod cups). Believe me I have tried them all and T&D is a much better set-up.
T&D also makes a paired shaft set-up that is hands down the best rocker system you can buy. You can even go to a steel rocker with those. more money (YES) but piece of mind that you will not have valve train issues is well worth it in the end.
beer
Re: Rocker Advice [Re: AndyF] #2643752
04/10/19 06:08 PM
04/10/19 06:08 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Originally Posted by AndyF
... The Mancini rocker arms would work okay with that cam and save you a bunch of money.
There's my vote.
Seems like some people are really quick to steer people towards $1000 rocker setups when the stuff in that price range is way overkill for what the OP described.
Re: Rocker Advice [Re: BradH] #2643756
04/10/19 06:39 PM
04/10/19 06:39 PM
Texas
mprhound Offline
mprhound  Offline
Texas
I have a set of RAS 1.6 rockers I would sell, pm me if you are interested.
Re: Rocker Advice [Re: BradH] #2643760
04/10/19 06:44 PM
04/10/19 06:44 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
There's my vote.
The difference is more than just money.
Maybe you want to upgrade down the road ?
Maybe you just like the certainty that you have done everything to insure against part failure.
Bust a cheap rocker and send hundreds of little pieces of " Awwwww , crap " into your motor and then you will hate hind sight.
There are areas where you should look to save money , and some where it just doesn't make sense to me.
