Rocker Advice
#2643445
04/09/19 09:46 PM
04/09/19 09:46 PM
Posts: 2 Kansas, US
brianlinn
Kansas, US
Apologies for asking a question that has been asked time and time again... I’m building a full roller 440, 10.5:1, Edelbrock Performer Heads, Edelbrock Performer intake, Demon 850 carb, Howard’s Roller cam (278 283 duration .531 .547, .230 .236 @ 50 with 1.5 rockers). I’m looking for 1.6 roller rockers and curious which is better as far as Jesel , Harland Sharp, T&D etc... This is just a little street/strip car. Looking for quality, durability and longevity. I appreciate any and all thoughts. Thanks!
Re: Rocker Advice
[Re: brianlinn]
#2643452
04/09/19 10:09 PM
04/09/19 10:09 PM
Posts: 614 Michigan
Get-X
Apologies for asking a question that has been asked time and time again... I’m building a full roller 440, 10.5:1, Edelbrock Performer Heads, Edelbrock Performer intake, Demon 850 carb, Howard’s Roller cam (278 283 duration .531 .547, .230 .236 @ 50 with 1.5 rockers). I’m looking for 1.6 roller rockers and curious which is better as far as Jesel , Harland Sharp, T&D etc... This is just a little street/strip car. Looking for quality, durability and longevity. I appreciate any and all thoughts. Thanks! The Harlan Sharps and T&D are both excellent rockers. If I had to choose between them I'd use the T&Ds. I wasn't aware that Jesel was making a shaft rocker kit for that combo?
'65 Belvedere '68 GTX '57 Dodge pickup
Re: Rocker Advice
[Re: Get-X]
#2643455
04/09/19 10:23 PM
04/09/19 10:23 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If it was me for that combo I would go with Harland Sharp rockers and I would be on the look out for a 10% off coupon for Summit.
Re: Rocker Advice
[Re: brianlinn]
#2643475
04/09/19 11:36 PM
04/09/19 11:36 PM
Posts: 43,317 Bend,OR USA
Cab_Burge
I've used all kinds of different brand and material type rocker arms on BB Mopar motors for drag racing and street use. I have found a bunch of variance on lift at the retainers on all of them including the T&D single shaft, on your deal I would go with the full roller Harland Sharps, not the newer cheaper extruded aluminum street sets ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) Call them and talk to Steve and tell him exactly what ratio you want so they can build them that way, there standard off the shelf set of 1.6 ratio will usually measure at the retainers with checking springs to be 1.65 or so ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) I had them make me a new set for a set of Indy 440-1 heads and told him I wanted between 1.57 to no more than 1.60 ratio three months ago and they ended up checking out to be 1.59 ratio at the retainers ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I will be building a new semi all out BB Mopar 555 C.I. drag race motor in the next year or so for myself that will have a set of B1-MC heads with a set of custom made steel T&D pair shaft rocker arm set up for those heads, not cheap or quick but quality never is ![work work](/ubbthreads/images/graemlins/custom/work.gif)
Re: Rocker Advice
[Re: parksr5]
#2643493
04/10/19 02:06 AM
04/10/19 02:06 AM
Posts: 608 TN
1DGEMAN
TN
Can't answer your question as I don't have any experience with the rocker arms you've mentioned but, I hear Rocker Arms Unlimited (previously RAS) is making their rocker arms again. Many people have praised them. Something to maybe look in to. Ran those on my NHRA stocker engines, Great product,
Real Men shift for themselves
Re: Rocker Advice
[Re: pittsburghracer]
#2643621
04/10/19 11:27 AM
04/10/19 11:27 AM
Posts: 13,405 Marion, South Carolina [><]
an8sec70cuda
If it was me for that combo I would go with Harland Sharp rockers and I would be on the look out for a 10% off coupon for Summit. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif)
Re: Rocker Advice
[Re: MR_P_BODY]
#2643676
04/10/19 02:01 PM
04/10/19 02:01 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I called Harlan Sharp and asked if they could make me 8 small block Mopar rockers with a .350 intake offset for a set of Edelbrock heads I’m playing with. He quoted me a very fair price and I had them less than 10 days later.
Re: Rocker Advice
#2643681
04/10/19 02:14 PM
04/10/19 02:14 PM
an8sec70cuda
HS made us a custom offset set of shaft mount rockers for the SB Chevy in the Camaro. Nice stuff and great service...everyone thinks they're T&D rockers when we have the covers off b/c they aren't the typical gold/amber HS color.
Re: Rocker Advice
[Re: AndyF]
#2643752
04/10/19 06:08 PM
04/10/19 06:08 PM
BradH
... The Mancini rocker arms would work okay with that cam and save you a bunch of money. There's my vote. Seems like some people are really quick to steer people towards $1000 rocker setups when the stuff in that price range is way overkill for what the OP described.
Re: Rocker Advice
[Re: BradH]
#2643756
04/10/19 06:39 PM
04/10/19 06:39 PM
Posts: 409 Texas
mprhound
Texas
I have a set of RAS 1.6 rockers I would sell, pm me if you are interested.
Re: Rocker Advice
[Re: BradH]
#2643760
04/10/19 06:44 PM
04/10/19 06:44 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
... The Mancini rocker arms would work okay with that cam and save you a bunch of money. There's my vote. Seems like some people are really quick to steer people towards $1000 rocker setups when the stuff in that price range is way overkill for what the OP described. The difference is more than just money. Maybe you want to upgrade down the road ? Maybe you just like the certainty that you have done everything to insure against part failure. Bust a cheap rocker and send hundreds of little pieces of " Awwwww , crap " into your motor and then you will hate hind sight. There are areas where you should look to save money , and some where it just doesn't make sense to me.
