To brace or not to brace? front Lexan. "Update"
#2643373
04/09/19 07:00 PM
04/09/19 07:00 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
Just took out all my glass and went to lexane. All came out good But a little concerned about the front windshield. I opted to bolt it in and remove the rubber and molding with the kit supplied And seems pretty solid but thinking at 140 it might push a little hard. What is everyone's Thoughts on bracing the center? If yes you have any pics? Thanks in advance π
"Update"
First run off the trailer and it rattled pretty good, was a little concerned it might come on on me but was good when I got back down to under 100. Made a little center brace from 3/4" flatstock aluminum and wrapped in J Waxler's secret Tape, screwed it into the roof and didn't even notice it after that.π
Founder and CEO of the Central Valley Mopar Drag Pack
Re: To brace or not to brace? front Lexan.
[Re: mikeysmopars]
#2643374
04/09/19 07:03 PM
04/09/19 07:03 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Just took out all my glass and went to lexane. All came out good But a little concerned about the front windshield. I opted to bolt it in and remove the rubber and molding with the kit supplied And seems pretty solid but thinking at 140 it might push a little hard. What is everyone's Thoughts on bracing the center? If yes you have any pics? Thanks in advance π .. in my opinion it would depend on what thickness of lexan you used
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: mikeysmopars]
#2643381
04/09/19 07:10 PM
04/09/19 07:10 PM
Posts: 52,972 Romeo MI
MR_P_BODY
3/16 wont need the brace EDIT If you use screws to screw it in you will be fine and it wont flex much at all.. I run 1/8" on my car at 152 mph ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: mikeysmopars]
#2643384
04/09/19 07:13 PM
04/09/19 07:13 PM
Posts: 1,647 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
How thick is the lexan? Here is a pic of the 2 supports on my windshield. Metal rod with clear vinyl tube sliced and slid over support rod. You can't see them very much.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: Dartsport540]
#2643385
04/09/19 07:21 PM
04/09/19 07:21 PM
mikeysmopars
fresno ca
Looks good, thanks for the pix!
[Re: MR_P_BODY]
#2643387
04/09/19 07:23 PM
04/09/19 07:23 PM
mikeysmopars
fresno ca
3/16 wont need the brace Thanks PBody, I've heard several guys say it's not a problem.
[Re: Stanton]
#2643390
04/09/19 07:32 PM
04/09/19 07:32 PM
mikeysmopars
fresno ca
3/16 ... brace it !! It may not end up in your lap BUT if it flexes in its causing more drag than in its intended position. Good point!
[Re: mikeysmopars]
#2643405
04/09/19 08:35 PM
04/09/19 08:35 PM
Posts: 22,728 Bitopia
jcc
Bitopia
I also would brace it, a tire(?) piece from another car at 140mph will put the whole thing in your lap, because lexan is not likely break, and that would hurt.
[Re: J_BODY]
#2643629
04/10/19 11:50 AM
04/10/19 11:50 AM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
The Cuda was 3/16 from Proglass in the stock gasket with the stock trim and went 171 with no brace and no problems.
