To brace or not to brace? front Lexan. "Update" #2643373
04/09/19 07:00 PM
04/09/19 07:00 PM
fresno ca
mikeysmopars Offline OP
fresno ca
Just took out all my glass and went to lexane. All came out good
But a little concerned about the front windshield. I opted to bolt it in and remove the rubber and molding with the kit supplied
And seems pretty solid but thinking at 140 it might push a little hard. What is everyone's
Thoughts on bracing the center? If yes you have any pics?
Thanks in advance πŸ˜‰
"Update"
First run off the trailer and it rattled pretty good, was a little concerned it might come on on me but was good when I got back down to under 100. Made a little center brace from 3/4" flatstock aluminum and wrapped in J Waxler's secret Tape, screwed it into the roof and didn't even notice it after that.πŸ‘
Founder and CEO of the Central Valley Mopar Drag Pack
Re: To brace or not to brace? front Lexan. [Re: mikeysmopars] #2643374
04/09/19 07:03 PM
04/09/19 07:03 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
.. in my opinion it would depend on what thickness of lexan you used
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: To brace or not to brace? front Lexan. [Re: WHITEDART] #2643378
04/09/19 07:05 PM
04/09/19 07:05 PM
fresno ca
fresno ca
3/16" Shiloh
Re: To brace or not to brace? front Lexan. [Re: mikeysmopars] #2643380
04/09/19 07:09 PM
04/09/19 07:09 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
3/16 ... brace it !! It may not end up in your lap BUT if it flexes in its causing more drag than in its intended position.
Re: To brace or not to brace? front Lexan. [Re: mikeysmopars] #2643381
04/09/19 07:10 PM
04/09/19 07:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
3/16 wont need the brace
EDIT
If you use screws to screw it in you will be fine and it wont flex
much at all.. I run 1/8" on my car at 152 mph
wave
Re: To brace or not to brace? front Lexan. [Re: mikeysmopars] #2643384
04/09/19 07:13 PM
04/09/19 07:13 PM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
How thick is the lexan? Here is a pic of the 2 supports on my windshield. Metal rod with clear vinyl tube sliced and slid over support rod. You can't see them very much.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: To brace or not to brace? front Lexan. [Re: Dartsport540] #2643385
04/09/19 07:21 PM
04/09/19 07:21 PM
fresno ca
fresno ca
Looks good, thanks for the pix!
Re: To brace or not to brace? front Lexan. [Re: MR_P_BODY] #2643387
04/09/19 07:23 PM
04/09/19 07:23 PM
fresno ca
fresno ca
wave
Thanks PBody, I've heard several guys say it's not a problem.
Re: To brace or not to brace? front Lexan. [Re: Stanton] #2643390
04/09/19 07:32 PM
04/09/19 07:32 PM
fresno ca
fresno ca
Good point!
Re: To brace or not to brace? front Lexan. [Re: mikeysmopars] #2643405
04/09/19 08:35 PM
04/09/19 08:35 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I also would brace it, a tire(?) piece from another car at 140mph will put the whole thing in your lap, because lexan is not likely break, and that would hurt.
Re: To brace or not to brace? front Lexan. [Re: jcc] #2643425
04/09/19 09:11 PM
04/09/19 09:11 PM
fullmetaljacket Offline
3/16 is the same thickness as the original glass. You won't need a brace as if you were using 1/8th.
With all those screws planting on all sides, it will be fine. I'm about 9 miles per hour slower than you and my 3/16th doesn't budge a hair.
Maybe a pot hole in Manhattan will make it flinch though. LOL.
Re: To brace or not to brace? front Lexan. [Re: fullmetaljacket] #2643437
04/09/19 09:32 PM
04/09/19 09:32 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
I've been 170 in my stratus with 1/8" lexan and no brace...
Re: To brace or not to brace? front Lexan. [Re: mikeysmopars] #2643526
04/10/19 07:46 AM
04/10/19 07:46 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Looks good Mike!! ....but there’s been some times I still like being able to roll that window down!! πŸ₯΅
Re: To brace or not to brace? front Lexan. [Re: J_BODY] #2643629
04/10/19 11:50 AM
04/10/19 11:50 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
The Cuda was 3/16 from Proglass in the stock gasket with the stock trim and went 171 with no brace and no problems.
