Anyone use Fluid Film? #2642385
04/07/19 06:16 PM
04/07/19 06:16 PM
middle Tennessee
mopower440 Offline OP
middle Tennessee
Im in the process of rebuilding the front end of the dart and got a nice pair of rebuilt lower control arms that are just bare metal and i really like how they look. I have a can of fluid film and thinking about leaving them bare metal and just coating them with the fluid film, kinda like the factory used to do with the cosmoline. The car is garage kept and not driven in the rain and lucky to see 500 miles a year..Curious if the fluid film will keep the rust off them? Anyone here used it?
Re: Anyone use Fluid Film? [Re: mopower440] #2642388
04/07/19 06:35 PM
04/07/19 06:35 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
It stinks. People say it's great. But it stinks. I'll find another way.
2011 Drag Pak Challenger
Re: Anyone use Fluid Film? [Re: rickseeman] #2642444
04/07/19 08:45 PM
04/07/19 08:45 PM
GMP440 Offline
GMP440  Offline
What about using Slip Plate. Napa and Grainger sells it. You spray it on wait about 30 min before buffing. It does give a spot on look of cast iron. Probably would look on strut rods.
Grainger stocks it on their shelves. Napa, you probably need to order.
Re: Anyone use Fluid Film? [Re: GMP440] #2642535
04/07/19 11:57 PM
04/07/19 11:57 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Any oil will get dirty, wipe them off with thinner and clear them.
Re: Anyone use Fluid Film? [Re: 4406bbl] #2642656
04/08/19 10:45 AM
04/08/19 10:45 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I would not use Fluid Film for that. We use it at work for all kinds of stuff, however being a waxy kind of oil, all kinds of dust and dirt will stick to it.
Re: Anyone use Fluid Film? [Re: DaytonaTurbo] #2642677
04/08/19 11:23 AM
04/08/19 11:23 AM
NE
moparpoolman Offline
NE
This is what you want to use, Rust Prevention Magicâ„¢!
http://www.ecs-rpm.com/
https://www.youtube.com/watch?v=EQYu8P3uC9I
Re: Anyone use Fluid Film? [Re: moparpoolman] #2642775
04/08/19 02:36 PM
04/08/19 02:36 PM
middle Tennessee
middle Tennessee
Hmmm, how long does this hold up for before needing a recoat? never heard of it..
Re: Anyone use Fluid Film? [Re: mopower440] #2642827
04/08/19 04:28 PM
04/08/19 04:28 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Honestly, I used RPM and it did not hold up for me. Others say it works great.
Re: Anyone use Fluid Film? [Re: mopars4ever] #2642836
04/08/19 04:39 PM
04/08/19 04:39 PM
middle Tennessee
middle Tennessee
Did it still rust anyway, like it wasn't even coated?
Re: Anyone use Fluid Film? [Re: mopower440] #2642848
04/08/19 04:53 PM
04/08/19 04:53 PM
md
mopars4ever Offline
mopars4ever  Offline
md
It took longer then bare metal to rust but if it is going to be damp and get wet it didn`t last very long for me. As I said others say it works great. I guess you can be the judge.
Re: Anyone use Fluid Film? [Re: mopars4ever] #2643030
04/08/19 11:26 PM
04/08/19 11:26 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I will only tell you I bought a new dodge diesel in 2000, powerwashed the underside, wiped all bare metal with thinner, cleared all bare metal, 3m yellow body cavity sprayed the sheet metal....it all still looks like new. I have used oil based products before, always need to reapply and it gets dirty. Your results may vary, key was it was new and clean.
Re: Anyone use Fluid Film? [Re: GMP440] #2643031
04/08/19 11:27 PM
04/08/19 11:27 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
What Slip-Plate product are you referring to? I looked at Grainger and saw quite a few to pick from!
Thx,RT
Re: Anyone use Fluid Film? [Re: mopower440] #2643211
04/09/19 12:23 PM
04/09/19 12:23 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
Strictly for convenience in aerosol form and the local Napa store stocks it I buy this stuff for doing touch up and small parts. Once dry it does stay slightly tacky but protection is very good.
https://www.amsoil.com/shop/by-prod...-protectants/heavy-duty-metal-protector/
I normally buy 5 gallons of wax oil type product (Tecty) and use a dedicated spray gun for big areas and/or entire vehicle.
Re: Anyone use Fluid Film? [Re: RTSrunner] #2643287
04/09/19 03:51 PM
04/09/19 03:51 PM
GMP440 Offline
GMP440  Offline
https://www.grainger.com/product/SLIP-PLATE-Dry-Film-Lubricant-1WVK7
They stock it on their shelves. Check and see if there is a Grainger in your area.
