Page 1 of 4 1 2 3 4
Making it mine/Bigcube's Dart, Update #2641704
04/05/19 08:10 PM
04/05/19 08:10 PM
Glendora Ca.
Just-a-dart Offline OP
Glendora Ca.
As some of you know I bought Jim's(Bigcube) Dart a while back and have been marking it mine.
It will have a new gen3 Hemi/904 combo now and will be a well used bracket car now. Just thought
I would share a few pics. I am starting to get a little excited to see how this thing is going to run.
It will weigh in less now with new dash. Light steering column. Fiberglass deck lid. Smaller fuel cell.
439"alum block gen3 Hemi, lt weight protrans 904, smaller radiator, 1 seat, 1 battery with a lot less wire.
New wheels/tires
As with most projects it has grown, but for me that is normal. This is the 1st new Hemi I have been into
looks like it should make some steam, but I know some will not like it because it does not have a distributor (Hi John)
"Just a Bracket car dressed up like a streetcar"
Re: Making it mine/Bigcube's Dart [Re: Just-a-dart] #2641707
04/05/19 08:13 PM
04/05/19 08:13 PM
Glendora Ca.
Glendora Ca.
A few more
Re: Making it mine/Bigcube's Dart [Re: Just-a-dart] #2641718
04/05/19 08:28 PM
04/05/19 08:28 PM
Glendora Ca.
Glendora Ca.
A couple more pics
Re: Making it mine/Bigcube's Dart [Re: Just-a-dart] #2641719
04/05/19 08:30 PM
04/05/19 08:30 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Looks good!
Re: Making it mine/Bigcube's Dart [Re: Just-a-dart] #2641720
04/05/19 08:31 PM
04/05/19 08:31 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
VERY nice upgrades. How soon till it hits the track???
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Making it mine/Bigcube's Dart [Re: pittsburghracer] #2641722
04/05/19 08:35 PM
04/05/19 08:35 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Looks great! Best of luck with it. up
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Making it mine/Bigcube's Dart [Re: pittsburghracer] #2641723
04/05/19 08:36 PM
04/05/19 08:36 PM
Glendora Ca.
Glendora Ca.
This summer John.if I don't blow it up on the Dyno (ha ha)
Re: Making it mine/Bigcube's Dart [Re: Just-a-dart] #2641747
04/05/19 09:23 PM
04/05/19 09:23 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
Great, Im Drooling Again.... scope no
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: Making it mine/Bigcube's Dart [Re: Just-a-dart] #2641752
04/05/19 09:36 PM
04/05/19 09:36 PM
PA.
"Little"John
"Little"John
PA.
Can we get any engine build secrets or is that top secret. Lol. I for one look forward to results in a lighter type of car.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Making it mine/Bigcube's Dart [Re: pittsburghracer] #2641787
04/05/19 11:11 PM
04/05/19 11:11 PM
Glendora Ca.
Glendora Ca.
John it is no secret.
Arrow/mopar alum. block 4.155 bore x 4.05 stroke 12.5 comp, 6.125 rod 2.0 bearing .866 pin. With 1.5, 1.5 3.0 mm alky rings
Heads are 6.4 apache with some Brett Miller love, 2.14 / 1.65 stock valves, PSI 1515ml beehives with tiny ti retainers
Cam is hyd roller 258/264@ .050 .636/.620 lift 108 center. Intake is a Tall Ritter that Brett reshaped the plenum some / ported.
1050 e85 dom carb, hemi 6 ign, 1 7/8 to 2" step headers
This is my learn about gen3's motor. I will do a solid roller set up and try to make a little more power later
Re: Making it mine/Bigcube's Dart [Re: Just-a-dart] #2641792
04/05/19 11:23 PM
04/05/19 11:23 PM
gregsdart Offline
gregsdart  Offline
Lookin good, Rod!
Re: Making it mine/Bigcube's Dart [Re: gregsdart] #2641794
04/05/19 11:36 PM
04/05/19 11:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats a good lookin set up you have.. should run very well for you
wave
Re: Making it mine/Bigcube's Dart [Re: Just-a-dart] #2641800
04/06/19 12:07 AM
04/06/19 12:07 AM
PA.
"Little"John
"Little"John
PA.
Is that a custom ring pack and is that actual true valve lift with your rocker ratio. Sounds like a killler package. Goodluck
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Making it mine/Bigcube's Dart [Re: pittsburghracer] #2641806
04/06/19 12:35 AM
04/06/19 12:35 AM
SE Washington
Forest Offline
Forest  Offline
SE Washington
looks awesome, can you get a air filter on under the cowl hood?
Re: Making it mine/Bigcube's Dart [Re: Forest] #2641813
04/06/19 01:51 AM
04/06/19 01:51 AM
Glendora Ca.
Glendora Ca.
Thanks for the encouragement guys
John- ring pack is a total seal # CSH2012 35 .
Forrest- not really enough height for a big air cleaner. I have the shorter manifold too that I may try at some point with a air cleaner that will be a
science experiment.
Re: Making it mine/Bigcube's Dart [Re: Just-a-dart] #2641824
04/06/19 06:43 AM
04/06/19 06:43 AM
Tulsa OK
Bad340fish Online content
Bad340fish  Online Content
Tulsa OK
Looks Very Nice! Looking forward to results.
68 Barracuda Formula S 340
Re: Making it mine/Bigcube's Dart [Re: Bad340fish] #2641838
04/06/19 07:46 AM
04/06/19 07:46 AM
ohio
all spooled up Offline
ohio
cool build all ways loved jims dart seen it at Norwalk years ago it went in the 8s
Re: Making it mine/Bigcube's Dart [Re: all spooled up] #2641866
04/06/19 08:49 AM
04/06/19 08:49 AM
oregon
greendart408 Offline
oregon
I always wondered where that car went. Very nice, what wheels did you go with ? The trunk stripe is on backwards, sorry but I had to tell you. Glad it’s going to get used. How long until you get to make passes? Will be curious to see what it runs.👍
Re: Making it mine/Bigcube's Dart [Re: Just-a-dart] #2641898
04/06/19 10:46 AM
04/06/19 10:46 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
and no mention of the mythical unicorn Mopar engine here??? That’s right kids.... you’re looking at a REAL 440 HEMI! The one we’ve all had to endure listening as some 1/2 brain 3/4 race cam nimwit told us of “the one he had back in the day”.... (unable to grab $20 bill off dash option available)
Re: Making it mine/Bigcube's Dart [Re: Just-a-dart] #2641913
04/06/19 11:03 AM
04/06/19 11:03 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Looks amazing .. I have to say it will be another amazing car ..and welcome to the world of multiple layer fire suits and sweat...
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Page 1 of 4 1 2 3 4
