Making it mine/Bigcube's Dart, Update
#2641704
04/05/19 08:10 PM
04/05/19 08:10 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
As some of you know I bought Jim's(Bigcube) Dart a while back and have been marking it mine. It will have a new gen3 Hemi/904 combo now and will be a well used bracket car now. Just thought I would share a few pics. I am starting to get a little excited to see how this thing is going to run.
It will weigh in less now with new dash. Light steering column. Fiberglass deck lid. Smaller fuel cell. 439"alum block gen3 Hemi, lt weight protrans 904, smaller radiator, 1 seat, 1 battery with a lot less wire. New wheels/tires
As with most projects it has grown, but for me that is normal. This is the 1st new Hemi I have been into looks like it should make some steam, but I know some will not like it because it does not have a distributor (Hi John)
"Just a Bracket car dressed up like a streetcar"
Re: Making it mine/Bigcube's Dart
[Re: Just-a-dart]
#2641720
04/05/19 08:31 PM
04/05/19 08:31 PM
Posts: 20,192 PA.
pittsburghracer
"Little"John
"Little"John
PA.
VERY nice upgrades. How soon till it hits the track???
[Re: pittsburghracer]
#2641723
04/05/19 08:36 PM
04/05/19 08:36 PM
Just-a-dart
Glendora Ca.
This summer John.if I don't blow it up on the Dyno (ha ha)
[Re: Just-a-dart]
#2641752
04/05/19 09:36 PM
04/05/19 09:36 PM
Posts: 20,192 PA.
pittsburghracer
"Little"John
"Little"John
PA.
This summer John.if I don't blow it up on the Dyno (ha ha) Can we get any engine build secrets or is that top secret. Lol. I for one look forward to results in a lighter type of car.
#2641787
04/05/19 11:11 PM
04/05/19 11:11 PM
Just-a-dart
Glendora Ca.
John it is no secret.
Arrow/mopar alum. block 4.155 bore x 4.05 stroke 12.5 comp, 6.125 rod 2.0 bearing .866 pin. With 1.5, 1.5 3.0 mm alky rings
Heads are 6.4 apache with some Brett Miller love, 2.14 / 1.65 stock valves, PSI 1515ml beehives with tiny ti retainers
Cam is hyd roller 258/264@ .050 .636/.620 lift 108 center. Intake is a Tall Ritter that Brett reshaped the plenum some / ported.
1050 e85 dom carb, hemi 6 ign, 1 7/8 to 2" step headers
This is my learn about gen3's motor. I will do a solid roller set up and try to make a little more power later
[Re: Just-a-dart]
#2641800
04/06/19 12:07 AM
04/06/19 12:07 AM
Posts: 20,192 PA.
pittsburghracer
"Little"John
"Little"John
PA.
This is my learn about gen3's motor. I will do a solid roller set up and try to make a little more power later M Is that a custom ring pack and is that actual true valve lift with your rocker ratio. Sounds like a killler package. Goodluck
[Re: Forest]
#2641813
04/06/19 01:51 AM
04/06/19 01:51 AM
Just-a-dart
Glendora Ca.
Thanks for the encouragement guys
John- ring pack is a total seal # CSH2012 35 .
Forrest- not really enough height for a big air cleaner. I have the shorter manifold too that I may try at some point with a air cleaner that will be a science experiment.
[Re: Just-a-dart]
#2641824
04/06/19 06:43 AM
04/06/19 06:43 AM
Posts: 8,030 Tulsa OK
Bad340fish
Tulsa OK
Looks Very Nice! Looking forward to results.
68 Barracuda Formula S 340
[Re: Just-a-dart]
#2641913
04/06/19 11:03 AM
04/06/19 11:03 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Looks amazing .. I have to say it will be another amazing car ..and welcome to the world of multiple layer fire suits and sweat...
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
