Re: Anyone use Milodon BB dipstick?
[Re: BradH]
#2641404
04/05/19 12:39 AM
04/05/19 12:39 AM
Posts: 2,363 Cotati, CA
Dave Hall
Cotati, CA
If so, how's it work? Got pics, especially if you're using it with headers? Thanks - Brad A-Body, 400, TTI’s and Milodon dipstick. It positively stays down with multiple o-rings. Comes out the front away from the heat.
[Re: BradH]
#2641959
04/06/19 12:59 PM
04/06/19 12:59 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
I t's easy to install and use, looks clean. I like it.
Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: BradH]
#2642607
04/08/19 08:42 AM
04/08/19 08:42 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
I use the Milodon stick on my hemi. It was the only one I could get to fit w/ my headers. It's hidden behind the motorplate so you can't see it in any of the engine pics I have on my computer.
Never understood why you wouldn't want a dipstick...even on a race engine. Makes it quick and easy to check the oil level and to see if you have water and oil mixing. I get that it's one less place to leak oil and/or vacuum, but they aren't hard to seal. And the old saying that "if you need to check it, you need to change it"...yeah, I don't buy that. Most people change oil way more often than needed.
[Re: AndyF]
#2642705
04/08/19 12:14 PM
04/08/19 12:14 PM
BradH
What is the problem you are trying to solve? Do you need a locking dipstick to pass tech? No tech requirement, but I'd like to use something more secure (o-ring seal in handle) than stock. The Milodon looks perfect on paper (or still in the package), but the examples I've seen of how people have routed it for a BB w/ headers don't show what I was hoping. Someone else mentioned to me not using one because of how close it was to the headers, and I have the same concern. I don't like the idea of routing it forwards towards the fan, either. Funny(?) how it seems to be a really good choice for a Gen II Hemi, though. Guess I'll keep looking for options. ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
[Re: BradH]
#2642745
04/08/19 01:42 PM
04/08/19 01:42 PM
Posts: 17,914 S.E. Michigan
ZIPPY
S.E. Michigan
I admit I haven't used the Milodon. It just seems fancier than I need. I have had the best luck bending the tube where desired, and then dealing with the bracket second. On my Wedge I bent the tube towards the inner fender and then straight up to put it where I wanted. After that I welded an extension (piece of metal with a hole drilled in it) to the existing bracket, so it would bolt to the motor mount like a stock one. If a guy didn't have a welder, the extension bracket could be bolted or riveted instead. I'll jam my phone down there and take pics if it will help. On my Hemi I noticed all the "$pecial" parts out there were for stock exhaust manfolds. So I took a wedge stick, bent it as needed, cut the bracket off and relocated it. It's pretty close, I will probably need to either shorten it or bend it a little more once it's installed in the chassis. ![[Linked Image]](https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/download/Number/345580/filename/2018-12-24%2013.26.23.jpg) ![[Linked Image]](https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/download/Number/345581/filename/2018-12-24%2013.27.02.jpg) ![[Linked Image]](https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/download/Number/345582/filename/2018-12-24%2013.27.38.jpg)
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2642780
04/08/19 02:50 PM
04/08/19 02:50 PM
an8sec70cuda
Brad...I used a stock dipstick for an HP application on every BB wedge and header combo I ever had in my cuda. Stock heads and Edelbrock RPM heads w/ Hooker 1 7/8" headers and the 2" 5209 super comps. Also Indy SR heads w/ the TTI 2" to 2 1/8" step headers.
[Re: BradH]
#2644609
04/13/19 05:49 AM
04/13/19 05:49 AM
Posts: 1,805 ky hills
thehemikid
ky hills
What is the problem you are trying to solve? Do you need a locking dipstick to pass tech? No tech requirement, but I'd like to use something more secure (o-ring seal in handle) than stock. The Milodon looks perfect on paper (or still in the package), but the examples I've seen of how people have routed it for a BB w/ headers don't show what I was hoping. Someone else mentioned to me not using one because of how close it was to the headers, and I have the same concern. I don't like the idea of routing it forwards towards the fan, either. Funny(?) how it seems to be a really good choice for a Gen II Hemi, though. Guess I'll keep looking for options. Another option, Sorry I don't have a pic with the headers on (can get one if needed)...may not work for you, but did for me. You could use a truck type 90* fitting in the oil pan,... locate the fitting wherever for or aft in the pan that would help dodge your header issue. Run a short steel flared tubing then a union to the Milodon. The reason I went this route was the motor I have was already built and not drilled for a dipstick. I could've built a jig to drill it, but I have a lot going on in that area anyway with the main oil lines, pre-oiler lines, and a remote water drain hose. My dipstick can just hug the block behind all that. Chose not to come out between 1 and 3 primaries because it makes it so much easier to swing the wrench for the header bolts without the stick, and don't have to remove the stick to remove the headers. Figured the union might leak a little being the Milodon's lower tubing was a tad smaller than the steel tubing but not a drop yet,...but I only have 48 miles on it so far.
![Name: IMG_3551.JPG
ID: 357327 IMG_3551.JPG](/ubbthreads/ubbthreads.php/ubb/download/Number/357327/filename/IMG_3551.JPG)
