89 Dakota 3.9. Discovered by accident while changing the window relay/breaker, that the A/C blower fuse was melted and brown, but never blew. Needless to say it crumbled and fell apart trying to remove it and one of the legs broke off deep inside the box. Simple right. Snip the 2 wires and put in an inline fuse. Well, there is only a 1 brown wire going to the fuse and the other leg has a metal strip/common ground strap going to several fuses. I repaired what caused the fuse to burn, but not sure how to go about bypassing the box.
