Valve job secrets? #264052
03/24/09 12:02 AM
03/24/09 12:02 AM
Essex, Ont., Canada
Fishmarket Offline OP
Essex, Ont., Canada
How about sharing some of those valve job angles and tricks that nobody wants to give out? I'm tinkering with a set of 6077 sb eddys for a 418CI street strip motor. I'm thinking of using some 2.055 valves and want to get an idea of what works.
Come on! I'm really starting to miss all of that really technical stuff and pics of ported heads that drew me to this site a few years ago...
1972 Plymouth Cuda 340 4 speed 1971 Plymouth Road Runner 383 Auto 1970 Plymouth Duster /6 Auto
Re: Valve job secrets? [Re: Fishmarket] #264053
03/24/09 12:14 AM
03/24/09 12:14 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Good luck.
Re: Valve job secrets? [Re: goldmember] #264054
03/24/09 06:56 PM
03/24/09 06:56 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
all jokes aside.... it seems everyone wants to show you how "pretty" their port work is, or tell us about every "big brown truck" that comes along. BUT, trying to squeeze that info might be like taking a banana from a monkey!
Re: Valve job secrets? [Re: Fishmarket] #264055
03/24/09 08:03 PM
03/24/09 08:03 PM
U.S.A.
Dartacus Offline
Dartacus  Offline
U.S.A.
Go to www.speedtalk.com and you will find alot of information and people willing to answer your questions there.
Re: Valve job secrets? [Re: Dartacus] #264056
03/24/09 08:24 PM
03/24/09 08:24 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
What secrets?Pick the valve size and angles that best suit your application or class rules.Keep the seat concentric and narrow.Check for good seal.Everything else is mathmetical measurements and pressures and geometry.Determine flow for cam,compression and engine size as well as induction.
Re: Valve job secrets? [Re: B G Racing] #264057
03/24/09 08:45 PM
03/24/09 08:45 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
see what i mean?
Re: Valve job secrets? [Re: Fishmarket] #264058
03/24/09 08:54 PM
03/24/09 08:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
There have been MANY hours and dollars of testing
to find the best flow and you exspect them to just
give it out .... buy their valve job and get out the
measuring equipment
Re: Valve job secrets? [Re: tjmarcus1] #264059
03/24/09 08:55 PM
03/24/09 08:55 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
see what i mean?
What? That covered a lot,anything else,you gotta pay for!!!Go to Mondello's school and see what it cost you
Re: Valve job secrets? [Re: B G Racing] #264060
03/24/09 09:06 PM
03/24/09 09:06 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
FYI, Serdi is running a special.........
Drawing fees waived on custom seat cutters.
6-10mm carbide pilots are $89.99
20% off on 5 or more items on Serdi repair parts.
Just thought I'd pass it along.
Re: Valve job secrets? [Re: S/ST 3040] #264061
03/24/09 09:12 PM
03/24/09 09:12 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
My guy Randy just got the newest state of the art Serdi,I'am not allowed near it.
Re: Valve job secrets? [Re: tjmarcus1] #264062
03/24/09 09:13 PM
03/24/09 09:13 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
see what i mean?
What about the weird wild wide world of "A" symmetrical valve work?
Re: Valve job secrets? [Re: dthemi] #264063
03/24/09 09:23 PM
03/24/09 09:23 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
see what i mean?
What,s Azzsymmetrical,I still use an old Sunnen orbital
Re: Valve job secrets? [Re: dthemi] #264064
03/24/09 10:48 PM
03/24/09 10:48 PM
Cab_Burge Online work
Cab_Burge  Online Work
see what i mean?
would that be 75degrees, 42 degrees and 29 degrees
Re: Valve job secrets? [Re: Cab_Burge] #264065
03/24/09 11:06 PM
03/24/09 11:06 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
That, apparently is the secret....
Re: Valve job secrets? [Re: Cab_Burge] #264066
03/24/09 11:12 PM
03/24/09 11:12 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
see what i mean?
Nope
Re: Valve job secrets? [Re: dthemi] #264067
03/24/09 11:21 PM
03/24/09 11:21 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
How aboiut cutting a lot of angles into the valve job?
Like 8 instead of 3?
I want my fair share
Re: Valve job secrets? [Re: B G Racing] #264068
03/24/09 11:30 PM
03/24/09 11:30 PM
Great White North Werst coast
runya Offline
runya  Offline
Crap..... know wonder I can't break into the 9's my concentrics are all wrong.
Bob if I box up my heads can you correct my geometry's and fix my cam angles?
Re: Valve job secrets? [Re: runya] #264069
03/25/09 01:37 AM
03/25/09 01:37 AM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Coatings of valves and seats are allowing much steeper valve angles that live and make serious HP improvements. Don't remember the exact numbers on the angles but they have seen 40-50 HP increases on the dyno by changing angles at a engine shop here in Indiana.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Valve job secrets? [Re: Irun5snd8th] #264070
03/25/09 08:56 AM
03/25/09 08:56 AM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Not that these #'s are going to do you alot of good unless you are willing to go have custom seat cutters made but... if you wanted to see some tech info....
Here's the seats that made 770HP with a set of 59* INDY heads...
Intake: 8MM radius,40*~.060" wide, 45* seat .051" wide, 60* .090" wide, & 72.5& bottom.... That cutter left with sharp 72.5 will be right at 90% throat at bottom of the 72.5 with proper bowl & valve sizing.
Exhaust: 8MM radius, 40* ~.040" wide, 45* seat .051" wide, 60* bottom. Blend everything away by had except the 45....I use that exhaust cutter on anything that I use a 45 seat on.
Good intake seat for an Edelbrock: 4MM radius, 35* ~.060" wide, 45* seat .051" wide, 60* ~.090" wide, 72.5-75 bottom. Set throat at 90%, intentionally sink seat until 35 degree top cut is ~.030"-.040" wide, & sink exhaust seat to match. I've had E heads go 9.80's @ 131 @ 3020 lbs with a 410" roller motor & 10.01 @ 129 @ 3000 with a flat tappet 408 with that basic valve seat cut on it. So if you can't make power with it, your problem is'nt in the VJ widths/angles.
My 50IN/50EX
52IN/55EX cutters are pirated from a Nascar shop & I won't be divulging those #'s. Only use that stuff on heads that have combustion chambers designed for it, raised ports, & alot of cam lift & ramp speed. Have never tried that stuff on the more pedestrian heads because I don't believe it will work, although if someone wants to take a gamble on their stuff someday I'll try it. I've found that sticking to "basics" usually makes more power than playing with the "trick of the week" sometimes. The simplest most basic motors I've done have made best power.....
Re: Valve job secrets? [Re: RyanJ] #264071
03/25/09 12:05 PM
03/25/09 12:05 PM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
stop doing that, or iam going to spell all the beans....
