Re: Exhaust Stud Removal
[Re: Lefty]
#264013
03/24/09 02:04 AM
03/24/09 02:04 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
leave them in,,, you wont have any water leaks...
I am truckless..
[Re: Moparmedic440]
#264017
03/24/09 09:22 AM
03/24/09 09:22 AM
Posts: 75,056 U.S.S.A.
JohnRR
U.S.S.A.
Does anybody know of a safe way to remove exhaust studs from a 440 head. I've had bad luck, the studs break off and when I use heat the head cracks easy. I need to get the studs out of a new engine I bought so I can use my haeders. Thanks for any help.
The heads crack easy with heat ??? What are you using a CUTTING TORCH ???
Headers , I'd leave them in if possible unless you are a Masochist and like having to drain your cooling system to replace a blown header gasket or replace the starter
[Re: Moparmedic440]
#264020
03/24/09 10:57 AM
03/24/09 10:57 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
The question is why? Why do you want them out? Are they all stripped out or something? If so get a good rust buster, soak, hit with a torch, soak, torch, then use the nut to nut method, before you try and turn it hit it with heat one more time. As stated, some are going to break so go get ya an extractor, tap and dye set Depending on the header you can use almost all or in some cases all of the exh mani studs.
