Exhaust Stud Removal #264010
03/23/09 11:30 PM
03/23/09 11:30 PM
Easton, Kansas
Moparmedic440 Offline OP
Easton, Kansas
Does anybody know of a safe way to remove exhaust studs from a 440 head. I've had bad luck, the studs break off and when I use heat the head cracks easy. I need to get the studs out of a new engine I bought so I can use my haeders. Thanks for any help.
Re: Exhaust Stud Removal [Re: Moparmedic440] #264011
03/23/09 11:46 PM
03/23/09 11:46 PM
Mansfield,Ohio
Brandon70cuda Offline
Mansfield,Ohio
I'd love to hear a good way too.
The only way I know is take them to the machine shop and let them cut'em out, my local shop charges $25 a stud or $30 if you broke an easy out in it like I did the first time.
Re: Exhaust Stud Removal [Re: Moparmedic440] #264012
03/24/09 01:41 AM
03/24/09 01:41 AM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I've found that welding a nut onto the stud with a mig welder seems to blast the rust off the threads. Maybe it's the current through the stud or maybe it's the heat?
I also drench them with Kroil or Heat penetrating oil the day before.
If I break one I weld a washer on end to the stud if there's enough metal left. You can mig real close to the head as the molten steel does not stick very well to the cast iron.
Re: Exhaust Stud Removal [Re: Lefty] #264013
03/24/09 02:04 AM
03/24/09 02:04 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
leave them in,,, you wont have any water leaks...
I am truckless..
Re: Exhaust Stud Removal [Re: 340SHORTY] #264014
03/24/09 02:08 AM
03/24/09 02:08 AM
Florida STAYcation
dOc … Online penguin-006
The village idiot's idiot
dOc …  Online Penguin-006
Florida STAYcation
IF you try an EZ-out ... use a QUALITY one of the square design....NOT the spiral one.
Re: Exhaust Stud Removal [Re: Moparmedic440] #264015
03/24/09 07:09 AM
03/24/09 07:09 AM
Southeast MI
ARETEE Offline
ARETEE  Offline
Southeast MI
You can try rapping them with a hammer before you double nut them. It tends to "shock" the threads to help break them loose....
Re: Exhaust Stud Removal [Re: ARETEE] #264016
03/24/09 08:49 AM
03/24/09 08:49 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Screw (2) nuts onto the stud. You use the nut that is closest to the head to remove the stud. That nut contacts the outside nut and they lock themselves together.
Re: Exhaust Stud Removal [Re: Moparmedic440] #264017
03/24/09 09:22 AM
03/24/09 09:22 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The heads crack easy with heat ??? What are you using a CUTTING TORCH ???
Headers , I'd leave them in if possible unless you are a Masochist and like having to drain your cooling system to replace a blown header gasket or replace the starter
Re: Exhaust Stud Removal [Re: burdar] #264018
03/24/09 09:26 AM
03/24/09 09:26 AM
Aurora Colorado
BELVEDERE67 Offline
mopar addict
BELVEDERE67  Offline
mopar addict
Aurora Colorado
I have used the double nut process as well. Use pb or any other penetrant...as well as heat and percussion adjustment......all to break the rust seal that is there. Use grade 8 nuts as it will require alot of pressure. Only done on 2 sets of heads but all studs came out.
Re: Exhaust Stud Removal [Re: BELVEDERE67] #264019
03/24/09 10:17 AM
03/24/09 10:17 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Something else that works other than PB is Anticease. PB seems to burn off with heat instead of flowing into the threads. If you use heat and then spread some anticease on the stud...it will become a liquid and run right into the threads without burning off.
Re: Exhaust Stud Removal [Re: Moparmedic440] #264020
03/24/09 10:57 AM
03/24/09 10:57 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
The question is why? Why do you want them out? Are they all stripped out or something? If so get a good rust buster, soak, hit with a torch, soak, torch, then use the nut to nut method, before you try and turn it hit it with heat one more time. As stated, some are going to break so go get ya an extractor, tap and dye set
Depending on the header you can use almost all or in some cases all of the exh mani studs.
Re: Exhaust Stud Removal [Re: Mr.Yuck] #264021
03/24/09 11:43 AM
03/24/09 11:43 AM
JohnRR Offline
JohnRR  Offline
If they are all rusty and or stripped I would just get a nut that slips over the stud and weld it to the stud , they should come right out .
