Re: high compression, NA street combos-pump 93
[Re: moparx]
#2638459
03/29/19 12:39 PM
03/29/19 12:39 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
as the title suggests, what combinations do/have you run on the street using pump 93 ? 493 stroker Eddy RPM heads cut to 76cc's and port matched Deck height .015" Scott Brown STF cam 259/266 @ .050 .637/.623 lift with 1.6 roller rockers Victor intake with 1050AN Quick Fuel 2" CPPA headers Timing all out by 2K 11.8:1 COMPRESSION 3926 LB B body 4 speed tranny with Centerforce clutch Pump gas 93 octane
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: moparx]
#2638467
03/29/19 01:07 PM
03/29/19 01:07 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
How high of a compression ratio are you wanting to know about? I shoot for 10.5 or less with aluminum heads on customers motors, 9.5 or less with iron heads ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I have a 505 C.I. 400 block that has a little over 11.3 to 1 compression ration due to the 440-1 heads having little tiny 50 CC combustion chambers ![shock shock](/ubbthreads/images/graemlins/custom/shock.gif) I haven't ran that motor in a car yet but I'm hoping the camshaft, 262@.050 intake and 263 @.050 on the exhaust lobes ground on a 105 LSA will drive okay with no pinging ![luck luck](/ubbthreads/images/graemlins/custom/luck.gif) My street pump gas stroker motor in my Duster started off with a set of mildly ported big valve 906 iron heads with 9.25 to1 compression that combination made my 3450 lb Duster run 10.69 at 124.+ MPH with a low deck six pack set up. I switch the heads to a set of CNC ported Eddy RPM with the same size combustion chambers that had the same compression ratio, those heads made the car pickup so it ran 10.49 at 126 MPH ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) The next winter I swap the crankshaft from a 4.25 stroke to a 4.300 stroke to raise the compression ratio up to 10.29 to 1 and that picked the car up to run 10.30 at 127. MPH. The last parts changed was another set of heads, Indy SR M.W. ports along with a Indy 400-1 intake and a 1050 CFM Holley Dominator carb, that ended with a best ET of 9.993 at 134.6 MPH ![boogie boogie](/ubbthreads/images/graemlins/custom/boogie.gif)
[Re: Brewzer67]
#2638572
03/29/19 06:29 PM
03/29/19 06:29 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
4.375 x 4.375 10.85 compression Ported TrickFlow PP 270's .714 tight lash solid roller (262@.050Int/268@.050Exh) .035 quench 20 degrees initial - 34 total in by 2800. Advance set to not start coming in until ~1600rpm (probably switching to locked distributor this summer) 180 stat 3800 stall 4.30 gear 3800 lb Coronet I run just regular 93 pump gas and have had no issues with detonation so far. No signs of it on any plugs, and nothing that was audible. I did sweat the details and made sure I knocked the sharp edges off anything in the combustion area and also polished the chambers to fight carbon buildup. I am a firm believer in a tight quench motor. My last build ran .027 piston to head clearance. On teardown I could see the slightest hint of a witness mark on the intake side of a few pistons so I opened it up a little on my next build. I didn't see any hint of collapsing the rind lands so I figure I was ok but still wanted a little insurance.
I hope this helps. That sounds like a nice combo! Any time slips that you care to share?
[Re: BradH]
#2638727
03/30/19 09:13 AM
03/30/19 09:13 AM
Posts: 19,629 north of coder
moparx
sorry. should have said above 10.0. just going through some mental exercises [at my age ? ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) ] and thought, or had, one of those "what if" moments. anyone else care to chime in ? thanks to those who responded so far ! ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: BradH]
#2638811
03/30/19 12:12 PM
03/30/19 12:12 PM
68LAR
South Park, Pa.
68LAR - 11.8? I thought you'd posted that you were about a full point lower (10.8?), but my memory's turning into putty. Nope, I don't remember posting that? But like you, my memory is also turning to putty. If I did post that, I was wrong and probably had a case of fat fingers and hit the wrong key?
[Re: cudadoug]
#2638850
03/30/19 01:57 PM
03/30/19 01:57 PM
Posts: 72 WI
Brewzer67
WI
I hope this helps. That sounds like a nice combo! Any time slips that you care to share? Unfortunately not yet. With what the heads flow (382@750 and really nice mid-lift numbers to match), I am hoping for anything sub 10 seconds. On paper, it should make it there but real life seldoms meets those predictions. Based on the prior motor, I am thinking it will likely be somewhere in the 10.20's. So far it is the best compromise motor I've built. Starts right up all the time, idles off within 40 or 50 seconds of running in 50 degree temps and isn't a pain to drive on the street or highway (other than the 4.30's being a little big but a tall tire and overdrive help that). It makes 2.5 hour journeys without flinching and still gets 11+ to the gallon on the highway.
[Re: Brewzer67]
#2638866
03/30/19 02:54 PM
03/30/19 02:54 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Much of the conversation depends on what you really want from your "High Compression NA Street Combo".
For instance, some people want to drive it hard on the street, and race it at the track with out ever adding race gas at all. Others, don't mind having an engine that runs good on the street with pump gas, but when they get to the track, and tune for best ET, they add race gas.
Still others have "Street engines" that have to be de-tuned and driven like an eggshell is under the pedal to avoid detonation on pump gas! I've had one of those and after awhile it just sucks the soul right out of you and makes the street experience unbearable! In combos where we've missed just a little, I will add race gas to every tank on the street because I refuse to not be able to enjoy the drive. My brothers, however, are cheap, so even many of their bracket cars were pump gas combinations because they refused to buy race gas.
The 428 small block in my Valiant is 11.0 to 1. 4.125 stroke by 4.07 bore. The flat tappet cam is 269/275 @ .050 , .600 lift, on a 111 c/l, installed at 107. Made 615hp @6700 on dyno. We don't have access to 93 most of the time, but I've ran it hard on 91, several times on Drag Week I've resorted to 89, and occasionally 87 with nary a whimper. Love this engine on the street!
The 580 Mega Block in Dale's Gremlin is 10.8 to 1. Nitrous spec cam is huge, 282/296 @ .050, 750/730 lift, 114 c/l. 352 cc Indy -1s, Tunnel Ram with twin Dominators. Runs around on pump gas with no issues, has been 9.47-144 NA with Nitrous gearing and bad converter.
One of the problems we've ran into is converting filled block race engines to street use, oil temperature control is tough, and as such they tend to be detonation prone in street use, even though the compression and cam seems like it should work.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MoparBilly]
#2638909
03/30/19 05:35 PM
03/30/19 05:35 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
11 to 1 iron magnum heads, 231@.050 110 LSA .575 lift single pattern cam. Full ported factory magnum heads 2.02 stainless valves mirror polished to keep from absorbing heat as much as possible 410 SB I pulled all the tricks I could think of to make it work, mopar air gap single plane intake, routed fuel lines outside frame away from ex heat, ceramic coated long tube headers, CAI picking up air in front of radiator, EFI, I cut all the webbing out of the accessories bracket to keep air flowing through intake, heat shield under intake to keep hot oil off intake, 160 t-stat, big diesel fan to keep lots of cooler air under hood, throttle response is insane and pulls hard from idle to 6000RPM.
[Re: Dragula]
#2638995
03/30/19 10:03 PM
03/30/19 10:03 PM
Posts: 10,020 Frostbitefalls MN (Rocky&Bullw...
gregsdart
This year we built a 512/400 at 13:1 and we will see if we can get it to run crap 93 with octane booster.... Me thinks you be messin with faith with that combination ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) Maybe try E85 instead ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) I'll have another post soon about a 518 C.I. 400 block I dyno tested this week on E85 after I figure out what part went south in the ignition system on the dyno yesterday ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) ![work work](/ubbthreads/images/graemlins/custom/work.gif) Hopefully I'll get it figure out this weekend We are starting on race fuel and going from there. Its mild enough to street it.....But we want to go faster than 9.70 on the track. Race/93 mix at the track, pull some timing and run 93 on the street😀
[Re: Dragula]
#2639040
03/31/19 12:47 AM
03/31/19 12:47 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Well mine is not what I call high comp as its 10.6 comp. I run a 440/493 combo that's a .030 over 440 with the 4.15 crank. I run on 92 pump since we have it in my area but it should run fine on 91 or less even as it has no detonation at all with 36 total timing. Here is the basics:
440 block with 4.15 crank
440Source stroker kit with D-dish pistons for 10.6 comp and .046 quench
The basic Indy EZ heads with some work from Dwayne Porter
Dwayne Porter solid flat tappet cam that's 264 & 270 @ .050 and .585 & .592 lift with a 110 LSA on a 106 ICL
Indy dual plane intake and 850 Holley DP
Mallory dist with MP orange ECU and 36 total timing
TTI 2" headers and the full 3" exh out the rear of the car with Ultra-Flow mufflers
Hughes roller tip rockers and Manton pushrods
Its in my 63 Sport Fury running a 727 with a 9.5 Dynamic converter and 4.30 gears using 30 x 9 Hoosier tires. I race my car just as I drive it on the street which is through the full exh on 92 pump. I don't change anything at the track as I built mine to race and drive without making any changes and I usually drive it to the track. Actually its never had race gas in it and I have never uncapped it. So far its run 10.70's . Ron
