Mini starter #2638262
03/28/19 09:39 PM
03/28/19 09:39 PM
Cleburne,Texas
scrapmetal Offline OP
Cleburne,Texas
I tried doing a search.I have a 69 valiant with a 470 ,tti headers,11:1 compression,and a 600 lift solid roller.Wich starter so I look for at the Auto parts?
Re: Mini starter [Re: scrapmetal] #2638268
03/28/19 09:52 PM
03/28/19 09:52 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Member 590challenger sells them. He is on Facebook too and runs the heads up blower car.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Mini starter [Re: pittsburghracer] #2638285
03/28/19 10:52 PM
03/28/19 10:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Get a mini starter for a Dakota (95 year is fine)
wave
Re: Mini starter [Re: MR_P_BODY] #2638286
03/28/19 10:54 PM
03/28/19 10:54 PM
Cleburne,Texas
Cleburne,Texas
Re: Mini starter [Re: scrapmetal] #2638294
03/28/19 11:13 PM
03/28/19 11:13 PM
AndyF Offline
AndyF  Offline
You might want to grab a cheap one at a starter rebuild place or a wrecking yard before you get too far into the project. Sometimes the mini starter doesn't fit with certain headers and/or blocks. If you have a cheap core sitting on the shelf you can make sure it fits before you buy a new one. Depending on your combination you might need the RobbMc starter.
Re: Mini starter [Re: scrapmetal] #2638295
03/28/19 11:16 PM
03/28/19 11:16 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
What Pman said! The starter I’m using was from my 95 Ram 1500 smile
Re: Mini starter [Re: AndyF] #2638296
03/28/19 11:19 PM
03/28/19 11:19 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
That’s a good point Andy. Fit like a glove with my 727. Only issue I had with 904 swap was the R3 block. Iirc it worked fine with our stock block build and 904
Re: Mini starter [Re: J_BODY] #2638445
03/29/19 12:04 PM
03/29/19 12:04 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Go buy one from Napa. Lifetime warranty. Make sure the battery stud won't hit the block.
Re: Mini starter [Re: Dave Hall] #2638460
03/29/19 12:41 PM
03/29/19 12:41 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
$39 shipped to your door, and work great.
https://www.ebay.com/itm/NEW-STARTER-FOR-MINI-MOPAR-DODGE-PLYMOUTH-318-360-400-HIGHER-TORQUE/302754993727?epid=12015830220&hash=item467d9a963f:g:24cAAOSw~BhbD49e
69 GTX 68 Road Runner
Re: Mini starter [Re: JERICOGTX] #2639290
03/31/19 07:34 PM
03/31/19 07:34 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Man that seems like a great deal. I may try one of these.
