Testing E-body factory switches #2638140
03/28/19 03:50 PM
03/28/19 03:50 PM
Scranton, PA
Montclaire Offline OP
Scranton, PA
Hello, I found two switches that were left over from a prior project. Pns are 2947305 and 2947411, which should be E-body headlamp and rear defogger. The car was sold so I can't test them in the car, how would I test these with a multimeter to see if they are good or not?
Re: Testing E-body factory switches [Re: Montclaire] #2638149
03/28/19 04:10 PM
03/28/19 04:10 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
I use a multi-meter and do continuity tests on them.
Using the FSM schematic wiring as a guide,I "turn on" the switch and check each connection pertaining to the setting the switch is at.
Pretty simple actually,Red terminal on my meter I use as power going in and black as power going out.
The spades on the switches are marked as well.
My multi-meter has a setting where it beeps when I close a circuit.
Hope this helps.
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: Testing E-body factory switches [Re: 68Cbarge] #2638276
03/28/19 10:24 PM
03/28/19 10:24 PM
Scranton, PA
Scranton, PA
I don't have a FSM and I wasn't going to buy one for a car I don't own anymore. What do you set the multimeter to? I am fine to follow instructions to diagnose things but I have no clue what function is appropriate for a given task. Thanks
Re: Testing E-body factory switches [Re: Montclaire] #2638291
03/28/19 11:10 PM
03/28/19 11:10 PM
to the lowest ohm setting it has. You would be checking continuity in the "on" position(s). Likely you can figure out which terminals are which from visual/experimentation AND www.mymoparts.com would likely have schematics.
