Anyone running any of the MP Gen II Hemi rockers #2637289
03/26/19 10:33 AM
03/26/19 10:33 AM
Aubigny, MB Canada
69 F5 R/T Offline OP
Aubigny, MB Canada
Curious if anyone has any feedback on any of the old MP rocker arm assemblies for the Gen II Hemi's?
Looking through the old catalogue and knowing how affordable the SS rollers were compared to anything else I've seen makes me go Hmmmmm.
Also, that Landy may have had a hand in their development, and I haven't heard of any failures, which you think you would if they were garbage.
Interesting also, that they went from stock ratio (whatever that's supposed to be lol) right to 1.7 on the mechanical offerings.
Dang, I'd be happy with a complete consistent 1.6 set!
Gotta be someone out there that has feedback or knowledge of these is use : )
Bringin Back the Iron!
Re: Anyone running any of the MP Gen II Hemi rockers [Re: 69 F5 R/T] #2637300
03/26/19 11:04 AM
03/26/19 11:04 AM
So. Burlington, Vt.
fast68plymouth Online content
fast68plymouth  Online Content
So. Burlington, Vt.
In typical MP fashion....... I have two catalogs from different years.
For the forged steel non-roller rockers, one catalog says the 1.65’s and 1.7’s are intake rockers...... and the other says they’re exhaust.
Re: Anyone running any of the MP Gen II Hemi rockers [Re: fast68plymouth] #2637346
03/26/19 12:51 PM
03/26/19 12:51 PM
Aubigny, MB Canada
Aubigny, MB Canada
To bad I can't get them anymore. The dealership that I deal with ( 25 years) would bring stuff like that in for me and verify without me having to commit to purchase.
I remember a miss listing on a Massi head that I had them bring in and it turned out to be just a 2.2 4 cyl head. If it would have been the Massi I would have cleaned them out! lol
Re: Anyone running any of the MP Gen II Hemi rockers [Re: 69 F5 R/T] #2637374
03/26/19 01:58 PM
03/26/19 01:58 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I collected several of the steel non-roller type, both NOS ones from MP and
a couple used sets of OE....but it will be awhile before I can check them,
and to be honest with the cam and springs I've chosen for my current build I
think I will probably go with Indy or one of the other less expensive roller tip styles.
The next one down the road will be more tame than this one, maybe with a solid flat
tappet and those stock style rockers will get used later on for sure.
Maybe I should mock them up and post the results?
But maybe it wouldn't be of any help, I dunno.
I don't have any of the roller tip style/commonly and probably correctly believed to be sourced from DLI
so maybe that wasn't the actual question..........
Rich H.
Esse Quam Videri
Re: Anyone running any of the MP Gen II Hemi rockers [Re: 69 F5 R/T] #2637394
03/26/19 03:11 PM
03/26/19 03:11 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I have them in my engine and they are the roller tip ones. When the engine had to come back apart we noticed that some had oiling holes for the push rod tips and some didn't. I guess QC is no a part of MP game plain.
Re: Anyone running any of the MP Gen II Hemi rockers [Re: ZIPPY] #2637431
03/26/19 05:13 PM
03/26/19 05:13 PM
Aubigny, MB Canada
Aubigny, MB Canada
I think with all of the rocker controversy, more and any info can't hurt, that's for sure!
And I was asking about any of the MP offerings, roller, mechanical and 1.7 ratio mechanical.
Re: Anyone running any of the MP Gen II Hemi rockers [Re: 71birdJ68] #2637433
03/26/19 05:15 PM
03/26/19 05:15 PM
Aubigny, MB Canada
Aubigny, MB Canada
That's good to know! Any issues with the lack of oiling holes?
How did they all look wear wise?
Re: Anyone running any of the MP Gen II Hemi rockers [Re: 69 F5 R/T] #2637485
03/26/19 08:21 PM
03/26/19 08:21 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
They only had about a 1000 miles on them when I had to re do the eng and that is when we found them. The machine shop jigged em up and added the holes and also some holes to squirt the roller tip, even though that probably wasn't really necessary. Wear wise, they looked ok. Be aware that with the roller tips and stock valve covers, the exhaust will beat the cover enough to put holes in it. Remember the old days when everybody had covers that had been welded up?
Re: Anyone running any of the MP Gen II Hemi rockers [Re: 71birdJ68] #2637502
03/26/19 09:03 PM
03/26/19 09:03 PM
Aubigny, MB Canada
Aubigny, MB Canada
So All roller rockers do this? Dang, was thinking maybe the MP units would be bolt-on and no modding : (
Maybe I just start looking for some wide pad mechanical stockers and start measuring...….
Re: Anyone running any of the MP Gen II Hemi rockers [Re: 69 F5 R/T] #2637506
03/26/19 09:17 PM
03/26/19 09:17 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Yep, roller rockers and stamped steel valve covers.........been there, done that. Took me 2 tries to get the clearance right.
I have an unused set of what I believe are MP non roller rocker assemblies that I will never use now. In case anyone was interested.
Master, again and still
Re: Anyone running any of the MP Gen II Hemi rockers [Re: 69 F5 R/T] #2637529
03/26/19 10:34 PM
03/26/19 10:34 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
With the two ears that the roller is between has to be longer than non rollers. One thing though, if you leave the stock covers black wrinkle then the dents are way down where almost nobody sees them. One good thing about a Hemi, those big heads and valve covers will hide a lot of stuff that you may not want to bee seen.
Re: Anyone running any of the MP Gen II Hemi rockers [Re: 71birdJ68] #2637629
03/27/19 09:48 AM
03/27/19 09:48 AM
Aubigny, MB Canada
Aubigny, MB Canada
So from everything I'm reading/ searching and understanding about the stock valvetrain, If one were to stay with mechanical rockers, these offerings from Mancini would be the best bet out there!
https://www.manciniracing.com/indy14.html
Affordable, better precision and quality control then factory stuff, and even a slightly Better ratio at 1.6/ 1.55.
Surprising I don't see or read of more people going to them.
Re: Anyone running any of the MP Gen II Hemi rockers [Re: 69 F5 R/T] #2637697
03/27/19 12:45 PM
03/27/19 12:45 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Be careful. those appear very close to the generics sold on ebay for $500 every now and then. Check the reputation out carefully.
Rich H.
Esse Quam Videri
Re: Anyone running any of the MP Gen II Hemi rockers [Re: 69 F5 R/T] #2637719
03/27/19 01:34 PM
03/27/19 01:34 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
You have three guesses on where those were made and the first two don't count.
Re: Anyone running any of the MP Gen II Hemi rockers [Re: 71birdJ68] #2637743
03/27/19 02:21 PM
03/27/19 02:21 PM
Aubigny, MB Canada
Aubigny, MB Canada
So Mancini sells Junk now?
Man, guess I've been under a rock all these past years. Could have swore they were stand up 20-30 years ago lol
Having said that, has anyone tried them? If they are better than the stockers, which apparently aren't that great, and there are no other offerings closer to Home, I would have no issues running them, regardless of where they were made......
Re: Anyone running any of the MP Gen II Hemi rockers [Re: 69 F5 R/T] #2637878
03/27/19 09:06 PM
03/27/19 09:06 PM
New England
Tech Instructor Offline
New England
I have the Indy rollers mine don't hit the covers chrome steel covers.
Re: Anyone running any of the MP Gen II Hemi rockers [Re: Tech Instructor] #2637896
03/27/19 10:00 PM
03/27/19 10:00 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Thank you, good info.
Rich H.
Esse Quam Videri
Re: Anyone running any of the MP Gen II Hemi rockers [Re: 69 F5 R/T] #2637908
03/27/19 10:27 PM
03/27/19 10:27 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Someday when I get the money, I'll get a set of Stage VI rockers. Here is a side note, a lot of Fuel cars have roller tip intake rockers and non roller exhaust.
Re: Anyone running any of the MP Gen II Hemi rockers [Re: 71birdJ68] #2637996
03/28/19 09:50 AM
03/28/19 09:50 AM
Aubigny, MB Canada
Aubigny, MB Canada
This as well as the Indy's clearing the stock stamped V/C are great pieces of info!
Really surprised there is no sticky'd thread showing all of the rocker options and their pro's and cons after all these years!
So Indy can make rollers that clear the stock steel V/C but no one else can? If that's true, I would think Indy would be the way to go for most wanting to run roller rockers. Really surprised the MP's don't clear and says nothing about it in the catalogue.
Re: Anyone running any of the MP Gen II Hemi rockers [Re: 69 F5 R/T] #2638012
03/28/19 10:26 AM
03/28/19 10:26 AM
Howell, Michigan
Hemidavey Offline
Hemidavey  Offline
Howell, Michigan
Buy thick gaskets and glue(not silicone) them together carefully. Worked for me, no dings with my rollers.
