Plastic Replica engine blocks
#2633701
03/17/19 02:00 PM
03/17/19 02:00 PM
Posts: 22,715 Bitopia
jcc
Bitopia
Never seen here much talk about using dummy engine blocks for fitment, etc.
So why the silence? Are they worth it? Are they useful? Do they hold up? Use it one time and keep it on the shelf or just sell it?
Re: Plastic Replica engine blocks
[Re: jcc]
#2633721
03/17/19 02:24 PM
03/17/19 02:24 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Why would you need one?
Unless you are doing a lot of builds putting that type engine into places it never went it's a luxury that's not needed.
[Re: Stanton]
#2633786
03/17/19 06:19 PM
03/17/19 06:19 PM
Posts: 643 southern conn
1969gtx
southern conn
I have a hemi block works grate for mock up light weight built 2 awb cars work nice for that
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
[Re: 1969gtx]
#2633893
03/18/19 12:18 AM
03/18/19 12:18 AM
jcc
Bitopia
I am doing an RB install with long rams in a car that they were never meant for. I'm getting old. muscling around 30lbs? to get the fit right vs the alternatives has got to be a plus.
We'll see.
Thanks.
[Re: jcc]
#2633937
03/18/19 08:38 AM
03/18/19 08:38 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
Before you start fabricating anything, make sure the dimensions are correct. I remember a while back someone had one that was off about 1/2"...could make for a big headache later.
[Re: an8sec70cuda]
#2633940
03/18/19 08:54 AM
03/18/19 08:54 AM
Posts: 2,533 God's Country Maryland
GODSCOUNTRY340
I've got one (440) and used it many times. All dimensions are correct, it even has the casting numbers on the sides. It looks like it was made right off a factory block with date casting and casting numbers. They cost over $400 new but they are sweet for quickly mocking up things like oil pan clearance, header clearance, anything in the engine compartment. Here I'm using it to put a 440 into a '54 flat fender Power Wagon.
[Re: AndyF]
#2634154
03/18/19 07:10 PM
03/18/19 07:10 PM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
I had a 440 one about 15 years ago. It was very accurate in dimensions. Sold it to someone, don't remember where.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: Dartsport540]
#2634445
03/19/19 02:11 PM
03/19/19 02:11 PM
Posts: 4,580 Motor City
6PKRTSE
Motor City
I just use an old hemi KB Fuel block with no sleeves for my mock up. Light enough I can set it in and remove from the chassis by hand with ease.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: AndyF]
#2634733
03/20/19 10:14 AM
03/20/19 10:14 AM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
I'd buy one for $75 but I'm not interested once the price is 3x or 4x that. Exactly. Summit lists the 426 at $550. Obviously chevys are cheaper, but some fords are actually more. For a one time mock up, that's a lot of bux. Even if you use it a few times, its a bit steep.
[Re: TC@HP2]
#2634746
03/20/19 10:48 AM
03/20/19 10:48 AM
an8sec70cuda
I just used an old 440 block when I had my car at the chassis shop for the cage and motorplate setup. Bolted the hemi heads onto the 440 block, sat it on the factory wedge mounts for motorplate positioning. Then hacked off the driver's side mount on the K frame to make sure the headers cleared.
[Re: TC@HP2]
#2634814
03/20/19 12:38 PM
03/20/19 12:38 PM
GODSCOUNTRY340
I'd buy one for $75 but I'm not interested once the price is 3x or 4x that. Exactly. Summit lists the 426 at $550. Obviously chevys are cheaper, but some fords are actually more. For a one time mock up, that's a lot of bux. Even if you use it a few times, its a bit steep. See if you can get a couple Mopar buddies and go in together. This way it won't hurt so much and you can all use it when you need it.
[Re: GODSCOUNTRY340]
#2634827
03/20/19 01:21 PM
03/20/19 01:21 PM
jcc
Bitopia
A new replica 440 long Block from Summit showed up today. Problem is, I don't have any buddies here, at least none that will admit to it. Seriously, it will be likely available in 6? months, as its a one off project at this point, let me know.
