Plastic Replica engine blocks #2633701
03/17/19 02:00 PM
03/17/19 02:00 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
Never seen here much talk about using dummy engine blocks for fitment, etc.
So why the silence?
Are they worth it?
Are they useful?
Do they hold up?
Use it one time and keep it on the shelf or just sell it?
Re: Plastic Replica engine blocks [Re: jcc] #2633721
03/17/19 02:24 PM
03/17/19 02:24 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Why would you need one?
Unless you are doing a lot of builds putting that type engine into places it never went it's a luxury that's not needed.
Don't be the exception.
Re: Plastic Replica engine blocks [Re: jcc] #2633733
03/17/19 02:55 PM
03/17/19 02:55 PM
AndyF Offline
AndyF  Offline
I've never had one in my hands to verify that the dimensions are correct. If the dimensions are all correct then I can see how it would be useful but you have to store it and it isn't useful for much else. For those reasons I just keep a spare block or two in my shop. That way I'm working with a real block that has the correct dimensions. I do have a dummy transmission that I use so I don't have to lift the real thing in and out of the car.
The local chassis shop is building a gasser B body right now and they borrowed a bare block, bare trans case and a set of bare heads from me so they could build engine mounts and fabricate the headers. That way the car will be ready to go when the customer gets his engine back from the engine builder. The chassis shop has Chevy engine cores for mockups but they didn't have a Mopar core so they asked for help.
Re: Plastic Replica engine blocks [Re: AndyF] #2633756
03/17/19 04:09 PM
03/17/19 04:09 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
They're primarily used for mockups when building a streetrod or race car chassis. There'd be no point for a resto or mild build. And they ain't cheap !!
Re: Plastic Replica engine blocks [Re: Stanton] #2633786
03/17/19 06:19 PM
03/17/19 06:19 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
I have a hemi block works grate for mock up light weight built 2 awb cars work nice for that
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: Plastic Replica engine blocks [Re: 1969gtx] #2633893
03/18/19 12:18 AM
03/18/19 12:18 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
I am doing an RB install with long rams in a car that they were never meant for. I'm getting old. muscling around 30lbs? to get the fit right vs the alternatives has got to be a plus.
We'll see.
Thanks.
Re: Plastic Replica engine blocks [Re: jcc] #2633937
03/18/19 08:38 AM
03/18/19 08:38 AM
an8sec70cuda Offline
Before you start fabricating anything, make sure the dimensions are correct. I remember a while back someone had one that was off about 1/2"...could make for a big headache later.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Plastic Replica engine blocks [Re: an8sec70cuda] #2633940
03/18/19 08:54 AM
03/18/19 08:54 AM
God's Country Maryland
GODSCOUNTRY340 Offline
I've got one (440) and used it many times. All dimensions are correct, it even has the casting numbers on the sides. It looks like it was made right off a factory block with date casting and casting numbers. They cost over $400 new but they are sweet for quickly mocking up things like oil pan clearance, header clearance, anything in the engine compartment. Here I'm using it to put a 440 into a '54 flat fender Power Wagon.
Re: Plastic Replica engine blocks [Re: GODSCOUNTRY340] #2634044
03/18/19 01:16 PM
03/18/19 01:16 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I picked mine up for $75.00 from a Moparts member several years ago. Not really anything you need for doing restorations but it did come in handy when I was setting up my engine run stand. It is very accurate in shape and size, most of the major OEM parts bolt right on. Also makes a cool shop ornament or man cave coffee table smile
Re: Plastic Replica engine blocks [Re: ScottSmith_Harms] #2634085
03/18/19 02:55 PM
03/18/19 02:55 PM
AndyF Offline
AndyF  Offline
I'd buy one for $75 but I'm not interested once the price is 3x or 4x that.
Re: Plastic Replica engine blocks [Re: AndyF] #2634154
03/18/19 07:10 PM
03/18/19 07:10 PM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
I had a 440 one about 15 years ago. It was very accurate in dimensions. Sold it to someone, don't remember where.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: Plastic Replica engine blocks [Re: Dartsport540] #2634445
03/19/19 02:11 PM
03/19/19 02:11 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I just use an old hemi KB Fuel block with no sleeves for my mock up. Light enough I can set it in and remove from the chassis by hand with ease.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Plastic Replica engine blocks [Re: AndyF] #2634733
03/20/19 10:14 AM
03/20/19 10:14 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Exactly. Summit lists the 426 at $550. Obviously chevys are cheaper, but some fords are actually more. For a one time mock up, that's a lot of bux. Even if you use it a few times, its a bit steep.
Re: Plastic Replica engine blocks [Re: TC@HP2] #2634746
03/20/19 10:48 AM
03/20/19 10:48 AM
I just used an old 440 block when I had my car at the chassis shop for the cage and motorplate setup. Bolted the hemi heads onto the 440 block, sat it on the factory wedge mounts for motorplate positioning. Then hacked off the driver's side mount on the K frame to make sure the headers cleared.
CHIP
Re: Plastic Replica engine blocks [Re: TC@HP2] #2634814
03/20/19 12:38 PM
03/20/19 12:38 PM
See if you can get a couple Mopar buddies and go in together. This way it won't hurt so much and you can all use it when you need it.
Re: Plastic Replica engine blocks [Re: GODSCOUNTRY340] #2634827
03/20/19 01:21 PM
03/20/19 01:21 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
A new replica 440 long Block from Summit showed up today. beer
Problem is, I don't have any buddies here, at least none that will admit to it. bawling laugh2
Seriously, it will be likely available in 6? months, as its a one off project at this point, let me know.
Re: Plastic Replica engine blocks [Re: jcc] #2634942
03/20/19 07:25 PM
03/20/19 07:25 PM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
a 426 hemi one on cl,st louis mo under mopar or dodge or 426 for 250.00
Re: Plastic Replica engine blocks [Re: rbkt65] #2635038
03/21/19 12:24 AM
03/21/19 12:24 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Link! Block
