Re: Alternative to OE style headlamp switch
[Re: lostdog]
#2632578
03/14/19 10:32 AM
03/14/19 10:32 AM
RapidRobert
on the high amp headlights you might relay it directly to the alt, good plan for heater/AC. No thoughts on the others
[Re: Slotts]
#2632615
03/14/19 12:12 PM
03/14/19 12:12 PM
Posts: 361 mississippi
lostdog
mississippi
Anyone have suggestions on switches other than OE to replace headlamp, wiper, and dome switches for ‘73 barracuda ? I AM NOT DOING A RESTORATION. I just need function. Thanks ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) Jim I know you are an advertiser and I looked through your online store and the site's vendor sponsors before I posted this only to find they are all expensive. I'm not saying I won't pay for what it takes to get the OE-style switches if that's what I have to do.
[Re: lostdog]
#2632646
03/14/19 01:27 PM
03/14/19 01:27 PM
Posts: 18,679 Fresno, CA
Jim_Lusk
Fresno, CA
Anyone have suggestions on switches other than OE to replace headlamp, wiper, and dome switches for ‘73 barracuda ? I AM NOT DOING A RESTORATION. I just need function. Thanks ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) Jim I know you are an advertiser and I looked through your online store and the site's vendor sponsors before I posted this only to find they are all expensive. I'm not saying I won't pay for what it takes to get the OE-style switches if that's what I have to do. You either know how to set up electrical or you pay somebody who does. It really is that simple (and so are the electronics on these old cars).
[Re: Montclaire]
#2632656
03/14/19 01:41 PM
03/14/19 01:41 PM
Posts: 7,982 Scranton, PA
Montclaire
Scranton, PA
I took a look at some of your posts and seeing as how your car was hacked up for drag racing, I think you should be looking at two options. One, you can try to find a whole dash assembly with the harness and cluster. Since you are looking for a 73 it might not cost as much as you may think, esp if it's a standard cluster. The other option would be to work with what you have and use a universal harness with aftermarket switches and gauges.
[Re: Jim_Lusk]
#2632665
03/14/19 02:27 PM
03/14/19 02:27 PM
lostdog
mississippi
Anyone have suggestions on switches other than OE to replace headlamp, wiper, and dome switches for ‘73 barracuda ? I AM NOT DOING A RESTORATION. I just need function. Thanks ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) Jim I know you are an advertiser and I looked through your online store and the site's vendor sponsors before I posted this only to find they are all expensive. I'm not saying I won't pay for what it takes to get the OE-style switches if that's what I have to do. You either know how to set up electrical or you pay somebody who does. It really is that simple (and so are the electronics on these old cars). I’m not finding it difficult to set up. I am without switches that’s all
[Re: Montclaire]
#2632667
03/14/19 02:32 PM
03/14/19 02:32 PM
lostdog
mississippi
I took a look at some of your posts and seeing as how your car was hacked up for drag racing, I think you should be looking at two options. One, you can try to find a whole dash assembly with the harness and cluster. Since you are looking for a 73 it might not cost as much as you may think, esp if it's a standard cluster. The other option would be to work with what you have and use a universal harness with aftermarket switches and gauges. I was able to get a cluster but none of the gauges worked so I installed modern gauges in their place. However, the cluster did not have headlamp, wiper or panel switches. I’m just looking for alternatives. I don’t want to cut anymore than I have to.
[Re: lostdog]
#2632729
03/14/19 05:47 PM
03/14/19 05:47 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Anyone have suggestions on switches other than OE to replace headlamp, wiper, and dome switches for ‘73 barracuda ? I AM NOT DOING A RESTORATION. I just need function. Thanks Not trying to be a jack-A$$, but toggle switches from the hard ware store fits this description. You could get it working for now and look for the proper switches later.
I have mechanical Aptitude. I can screw up anything.
[Re: lostdog]
#2632769
03/14/19 07:25 PM
03/14/19 07:25 PM
Jim_Lusk
Fresno, CA
no idea why that picture is upside down Cell phone pic. It seems that the orientation is almost always wrong and stays with the pic no matter what you do.
[Re: Dave Hall]
#2632863
03/15/19 12:56 AM
03/15/19 12:56 AM
Montclaire
Scranton, PA
Not sure how you would rig up one of those, pretty different from stock. For reference: 3420865 dimmer switch 2947305 headlamp switch 3621666 2 spd wiper 3621670 3 spd wiper
