Re: Alternative to OE style headlamp switch
[Re: lostdog]
#2632578
03/14/19 10:32 AM
03/14/19 10:32 AM
RapidRobert
on the high amp headlights you might relay it directly to the alt, good plan for heater/AC. No thoughts on the others
[Re: Slotts]
#2632615
03/14/19 12:12 PM
03/14/19 12:12 PM
Posts: 361 mississippi
lostdog
mississippi
Anyone have suggestions on switches other than OE to replace headlamp, wiper, and dome switches for ‘73 barracuda ? I AM NOT DOING A RESTORATION. I just need function. Thanks Jim I know you are an advertiser and I looked through your online store and the site's vendor sponsors before I posted this only to find they are all expensive. I'm not saying I won't pay for what it takes to get the OE-style switches if that's what I have to do.
[Re: lostdog]
#2632646
03/14/19 01:27 PM
03/14/19 01:27 PM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
Anyone have suggestions on switches other than OE to replace headlamp, wiper, and dome switches for ‘73 barracuda ? I AM NOT DOING A RESTORATION. I just need function. Thanks Jim I know you are an advertiser and I looked through your online store and the site's vendor sponsors before I posted this only to find they are all expensive. I'm not saying I won't pay for what it takes to get the OE-style switches if that's what I have to do. You either know how to set up electrical or you pay somebody who does. It really is that simple (and so are the electronics on these old cars).
[Re: Montclaire]
#2632656
03/14/19 01:41 PM
03/14/19 01:41 PM
Posts: 7,982 Scranton, PA
Montclaire
Scranton, PA
I took a look at some of your posts and seeing as how your car was hacked up for drag racing, I think you should be looking at two options. One, you can try to find a whole dash assembly with the harness and cluster. Since you are looking for a 73 it might not cost as much as you may think, esp if it's a standard cluster. The other option would be to work with what you have and use a universal harness with aftermarket switches and gauges.
[Re: Jim_Lusk]
#2632665
03/14/19 02:27 PM
03/14/19 02:27 PM
lostdog
mississippi
Anyone have suggestions on switches other than OE to replace headlamp, wiper, and dome switches for ‘73 barracuda ? I AM NOT DOING A RESTORATION. I just need function. Thanks Jim I know you are an advertiser and I looked through your online store and the site's vendor sponsors before I posted this only to find they are all expensive. I'm not saying I won't pay for what it takes to get the OE-style switches if that's what I have to do. You either know how to set up electrical or you pay somebody who does. It really is that simple (and so are the electronics on these old cars). I’m not finding it difficult to set up. I am without switches that’s all
[Re: Montclaire]
#2632667
03/14/19 02:32 PM
03/14/19 02:32 PM
lostdog
mississippi
I took a look at some of your posts and seeing as how your car was hacked up for drag racing, I think you should be looking at two options. One, you can try to find a whole dash assembly with the harness and cluster. Since you are looking for a 73 it might not cost as much as you may think, esp if it's a standard cluster. The other option would be to work with what you have and use a universal harness with aftermarket switches and gauges. I was able to get a cluster but none of the gauges worked so I installed modern gauges in their place. However, the cluster did not have headlamp, wiper or panel switches. I’m just looking for alternatives. I don’t want to cut anymore than I have to.
[Re: lostdog]
#2632729
03/14/19 05:47 PM
03/14/19 05:47 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Anyone have suggestions on switches other than OE to replace headlamp, wiper, and dome switches for ‘73 barracuda ? I AM NOT DOING A RESTORATION. I just need function. Thanks Not trying to be a jack-A$$, but toggle switches from the hard ware store fits this description. You could get it working for now and look for the proper switches later.
I have mechanical Aptitude. I can screw up anything.
[Re: lostdog]
#2632769
03/14/19 07:25 PM
03/14/19 07:25 PM
Jim_Lusk
Fresno, CA
no idea why that picture is upside down Cell phone pic. It seems that the orientation is almost always wrong and stays with the pic no matter what you do.
[Re: Dave Hall]
#2632863
03/15/19 12:56 AM
03/15/19 12:56 AM
Montclaire
Scranton, PA
Not sure how you would rig up one of those, pretty different from stock. For reference: 3420865 dimmer switch 2947305 headlamp switch 3621666 2 spd wiper 3621670 3 spd wiper
[Re: Montclaire]
#2632870
03/15/19 01:30 AM
03/15/19 01:30 AM
Montclaire
Scranton, PA
For what you are trying to do I would look for a combo headlamp/cluster dimmer switch and a matching 2 speed wiper. Something retro. That will leave you with an empty hole but I drove my 73 Challenger like that for ten years and it never bothered me. 73-76 a-body should work if you can find them cheap enough but there are probably other options out there (headlamp looks to be the same/similar to what's in the Rockauto link but you'd still need a knob/shaft) . My only concern would be things getting too crowded with the flared a-body knobs, might just have to try and see.
[Re: Montclaire]
#2632915
03/15/19 09:35 AM
03/15/19 09:35 AM
lostdog
mississippi
73-76 A-body 2 speed switches look very similar to 72-74 E-body. I think the only difference is the number and orientation of the tabs on the back of the switch. If you could find one in a bone yard and get a copy of the wiring diagram you could probably adapt it to work, it just won't fit the stock harness plug. 71-77 van/truck and F-body are similar too but with even more prongs. I have considered this too and it may work bc making an adapter would be easy . However those switches are really not much less than the E-body.
[Re: lostdog]
#2632947
03/15/19 10:38 AM
03/15/19 10:38 AM
Montclaire
Scranton, PA
Try the classifieds here or on Forabodiesonly.com. I think it would be worth it if you could find them at a reasonable price, getting the same length shaft might be tricky and I assume you want the knobs to match.
If you just want super cheap then you are going to have to hack up the panel you have and use HELP brand/GM stuff.
