Re: Any Holley HP users here?
[Re: Fishstix]
#2630451
03/08/19 04:31 PM
03/08/19 04:31 PM
Posts: 112 Michigan
ghinmi
I have Holley HP on mine with a cable throttle body. What part number main harness do you have and what throttle body/iac are you trying to control?
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street. 9.97 @ 140 slicks, 10.74 in autox trim
[Re: Fishstix]
#2630467
03/08/19 05:22 PM
03/08/19 05:22 PM
Posts: 112 Michigan
ghinmi
I was kind of hoping you wouldn't say the BBK hemi one. The non-dbw Holley harness has the 3 wires for a 5v reference TPS (5v, ground, signal) and 4 wires for a dual coil stepper type IAC. Holley uses the Chrysler IAC in their universal throttle bodies so the 115 harness is already wired correctly for the standard Chrysler 4 pin IAC.
The problem is that BBK decided to use the obscure 4.7 v8 IAC and TPS. I have tried to find control strategy for them in the past (and again today) with no luck. The most direct route would be to get an adapter plate and run a GM throttle body. That gets you a standard GM TPS and stepper motor. Less direct is a Ford fox body era 5.0 style throttle body but that uses a PWM output to control the IAC. I wish I could be of more help on the BBK throttle body/electronics.
[Re: Fishstix]
#2630516
03/08/19 07:35 PM
03/08/19 07:35 PM
Posts: 112 Michigan
ghinmi
I wouldn't give up on that throttle body just yet, someone may have figured it out by now.
Mine is an old Ford style throttle body that I had laying around the shop collecting dust. I slotted the holes and bolted it right on. Had to make a throttle cable bracket. Because I bought mine before Holley offered a cable drive harness, it had no provisions for tps or iac so I had to wire them in myself. For yours, you would be able to use the existing 3 wires for the tps. The 4 wires for the iac would be discarded and you would have to use one of your pwm outputs to drive the iac.
A GM throttle body would use the same 3 wires for tps and same 4 wires for iac, just different order in a different plug end. Would be the easiest solution with the least wiring involved and still leave all 4 of your outputs.
[Re: Fishstix]
#2630540
03/08/19 08:39 PM
03/08/19 08:39 PM
Posts: 112 Michigan
ghinmi
Thank you!
Keep us posted on what you find out. I'm more than happy to help with wiring if you do end up going with a GM throttle body. And also if you run into any other Holley issues.
[Re: Fishstix]
#2632095
03/12/19 10:49 PM
03/12/19 10:49 PM
Posts: 112 Michigan
ghinmi
Awesome, glad you got it figured out! Could you post a link? Would like to learn as well.
