Page 1 of 5 1 2 3 4 5
" The Block" by Bulldog Performance #2630332
03/08/19 11:57 AM
03/08/19 11:57 AM
USA
hudsonhornet7x Offline OP
USA
On the forum here today is an article about the block from Bulldog. Does anyone have experience with this block or company? I am curious to find out if this is actually something we as Mopar folks can depend on for a block.
Re: " The Block" by Bulldog Performance [Re: hudsonhornet7x] #2630343
03/08/19 12:20 PM
03/08/19 12:20 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I believe member hugo here has one..
Re: " The Block" by Bulldog Performance [Re: hudsonhornet7x] #2630348
03/08/19 12:34 PM
03/08/19 12:34 PM
AndyF Offline
AndyF  Offline
Go visit a Buick forum and ask that question........
Re: " The Block" by Bulldog Performance [Re: hudsonhornet7x] #2630356
03/08/19 12:49 PM
03/08/19 12:49 PM
Sticky South
Rodenteliminator Offline
Sticky South
Well I have talked to Richard a couple of times with questions, he seems to be trying to do it right, so as of Wed I sent him a deposit to get the process started, he is telling me 6 to 8 weeks and the main holdup is the machining, so time will tell.
Sorry honey I spent the rent
Re: " The Block" by Bulldog Performance [Re: hudsonhornet7x] #2630362
03/08/19 12:57 PM
03/08/19 12:57 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Ahhh....I usually try to keep it positive here.
I think some/not a whole lot of their product has been sold and is out there.
Other than that, things seem to be a big ball of "not good"
https://www.yellowbullet.com/forum/showthread.php?t=342038
Rich H.
Esse Quam Videri
Re: " The Block" by Bulldog Performance [Re: hudsonhornet7x] #2630381
03/08/19 01:38 PM
03/08/19 01:38 PM
cleveland, ohio
AJsDUSTER Offline
AJsDUSTER  Offline
cleveland, ohio
I bought "THE" block from Muscle Motors in march of 2017. I was happy and excited, they said the only problem you might have is putting in the cam bearings is very tight. That wasn't the only problem.
it seems I got an early run block, most problems were fixable, but it would have been nice to know of the problems before a lot of test fitting, then put it together and find something else and take it apart.
'Ol Dick Bradshaw may have fixed those problems by now, who knows. If you want an Iron block, it seems like it is the only one out there, it is heavy, at least over 305 lbs. maybe more depending your bore size.
If you want one buyer beware twocents, I might go through "Best Machining" I think they know a lot about them.
Re: " The Block" by Bulldog Performance [Re: AJsDUSTER] #2630397
03/08/19 02:02 PM
03/08/19 02:02 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I can't figure that one out. If the cam bores are too tight, put it in the Tobin-Arp and cut them to the proper size. I mean, this ain't rocket science for a block manufacturer. WOW.
2011 Drag Pak Challenger
Re: " The Block" by Bulldog Performance [Re: Rodenteliminator] #2630412
03/08/19 02:39 PM
03/08/19 02:39 PM
New York
polyspheric Offline
polyspheric  Offline
New York
"the main holdup is the machining": it won't be done, and it's not my fault
Boffin Emeritus
Re: " The Block" by Bulldog Performance [Re: Rodenteliminator] #2630438
03/08/19 04:11 PM
03/08/19 04:11 PM
AndyF Offline
AndyF  Offline
If you go read the Buick threads you'll find that Dick told them the same thing for 5+ years. I don't know the guy and I've never tried to work with him but I've seen his name on various forums for more than 10 years. The threads about him are always very, very negative.
Re: " The Block" by Bulldog Performance [Re: hudsonhornet7x] #2630439
03/08/19 04:15 PM
03/08/19 04:15 PM
AndyF Offline
AndyF  Offline
MarkZ has one of those blocks. If I remember correctly it was poorly machined from the get go and he had to have it redone by BES. I think the lifter bores were machined wrong. I'm sure there are threads on here about it.
Re: " The Block" by Bulldog Performance [Re: AndyF] #2630458
03/08/19 04:50 PM
03/08/19 04:50 PM
Sticky South
Sticky South
I talked to Hugo and Markz before I did this, and I have read the posts and heard the stories, all this race and aftermarket parts deal is a shot in the dark anyway.
Re: " The Block" by Bulldog Performance [Re: Rodenteliminator] #2630486
03/08/19 06:07 PM
03/08/19 06:07 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I've read all the crap as well. Conversations and observations at PRI have given me some hope that they've turned the corner. Will have to ask how things are going. What I saw was pretty, for what that's worth.
Re: " The Block" by Bulldog Performance [Re: Rodenteliminator] #2630500
03/08/19 06:37 PM
03/08/19 06:37 PM
It's Complicated
HDNMOPERS Offline
HDNMOPERS  Offline
It's Complicated
Got a call from Richard on Tuesday. I like you just wanted to inquire about The Block. Told me the same thing he told you. Don't know the man whatsoever. But he's had some very unfavorable opinions of his business dealings. He was nice to speak with though. I just told him wish he had blocks on hand. I would most likely purchase one. But since he didn't. I didn't feel comfortable putting down a 1500 deposit.
Re: " The Block" by Bulldog Performance [Re: HDNMOPERS] #2630518
03/08/19 07:41 PM
03/08/19 07:41 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
So - I do have a "the block". Came from Muscle Motors. I have no idea how Richard Bradshaw is in the mix.
Best I can tell, Bill from the Chicago Connection funded the project and owns all the rights. This is as far as I can figure out. I have talked to Bill a few times.
If anyone wants one, I would be calling Bill at Chicago Connection not Dick Bradshaw.
Yes - mine had problems but they were all fairly easily fixed. I would buy another one in a heartbeat - but from Bill.
Re: " The Block" by Bulldog Performance [Re: hudsonhornet7x] #2630554
03/08/19 09:09 PM
03/08/19 09:09 PM
Laredo, Texas USA
hugo Offline
hugo  Offline
Laredo, Texas USA
I also did my research on Richard BRADSHAW. Some negative things about the guy. I talked to him and he had a block available at the time. I was very skeptic about buying it from him. He seemed a nice guy and knowledgeable. I trusted the guy. I sent him a check and in three days I had the block. He delivered! My experience with him was good. The block looks pretty good but I haven’t put it together since I am undecided of what to buil in the low deck 540, 557, 572? As far as the machining of the block until we start the build we will find out and I keep you guy informed. He did tell me if I wantedan rb which he did not have I’d had to wait 6 to 8 weeks. I think he designed it and builds it. As far as who sponsors him I have only read it’s Chicago connection. By the way I did talk to Eric from muscle motors since I have dealt with them before to ask them about the block and Richard BRADSHAW and if I could trust him. They told me I could trust the guy. I did and I do have the block in my hands.
Re: " The Block" by Bulldog Performance [Re: HDNMOPERS] #2630557
03/08/19 09:14 PM
03/08/19 09:14 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I don't know him, but ask "Has all of the deposit money collected been deposited in an escrow account?", and he will squirt out a cloud of ink and swim away backward.
It's a Ponzi - after he spent the deposits on personal expenses he can't pay the foundry, his staff, machine shop, or even rent... until he takes more deposits... which he spends.
What did you THINK was happening?
Used before that I know of in other industries: his wife/friend starts a new corporation which lends him $1,000,000. Now, when he goes bankrupt, HE is his largest creditor and gets back all of his own inventory for 10¢ on the dollar (stiffing the other complainants). Opens new business, sells the same parts you already bought a second time. Rinse, repeat.
Boffin Emeritus
Re: " The Block" by Bulldog Performance [Re: polyspheric] #2630632
03/09/19 02:48 AM
03/09/19 02:48 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
The only thing I can say is the problem is NOT machine work.
Re: " The Block" by Bulldog Performance [Re: slantzilla] #2630660
03/09/19 09:33 AM
03/09/19 09:33 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
FWIW .My brother bought 3 blocks , 9.98 DH, 4.49 bore 60 MM cam Hemi Bolt pattern , Lifters were unmachined, because we were using Frankenstein P48 Hemi heads. Ordered in Late October, delivered last week of January.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: " The Block" by Bulldog Performance [Re: ric3xrt] #2630763
03/09/19 01:59 PM
03/09/19 01:59 PM
Mesa, AZ
Bill_T Offline
Bill_T  Offline
Mesa, AZ
I'd like to hear more about these....
This space not for rent.
Re: " The Block" by Bulldog Performance [Re: Bill_T] #2630804
03/09/19 03:20 PM
03/09/19 03:20 PM
Conroe , Texas
I
iapco103 Offline
iapco103  Offline
I
Conroe , Texas
Turned in my order to Bulldog a couple of weeks ago for a Hemi block, also told 6-8 weeks. We will see how it goes. Paul
