Re: 71 Cuda ignition problem. [Re: Warrior] #2628482
03/03/19 11:28 PM
03/03/19 11:28 PM
Yes, it makes up for Mr Murphy.
Re: 71 Cuda ignition problem. [Re: moparpoolman] #2628491
03/03/19 11:46 PM
03/03/19 11:46 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Originally Posted By moparpoolman
check / test ballast resistor
Actually a damaged ballast won't start up ever if car is electronic ignition. Just will allow to fire up with points setup while cranking, but will stall when coming back to RUN
Re: 71 Cuda ignition problem. [Re: NachoRT74] #2628516
03/04/19 12:23 AM
03/04/19 12:23 AM
^^^ correct, ECU will not get fed in ign2 (crank)
Re: 71 Cuda ignition problem. [Re: RapidRobert] #2628665
03/04/19 01:38 PM
03/04/19 01:38 PM
moparx Offline
moparx  Offline
glad the cause was found ! up
beer
Re: 71 Cuda ignition problem. [Re: moparx] #2628852
03/04/19 09:02 PM
03/04/19 09:02 PM
N.y
W
Warrior Offline OP
Warrior  Offline OP
W
N.y
Me too 🇺🇸. Just trying to figure out who sells the better ignition switch. The one that’s in there is from standard. Put it in 13 months ago. Nothing is made here anymore. Junk is junk. Thanks again for your help!
Re: 71 Cuda ignition problem. [Re: Warrior] #2628957
03/05/19 01:26 AM
03/05/19 01:26 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
believe or not, I have replaced some parts on my car with used parts from JYs than looks somehow WAY BETTER than new replacements
Re: 71 Cuda ignition problem. [Re: NachoRT74] #2628961
03/05/19 01:32 AM
03/05/19 01:32 AM
Agreed quality is down but I think with another switch you will be OK. EDIT & if going to a yard is practical I think that would get you a good used one in hand.
Re: 71 Cuda ignition problem. [Re: NachoRT74] #2629874
03/07/19 08:38 AM
03/07/19 08:38 AM
N.y
W
Warrior Offline OP
Warrior  Offline OP
W
N.y
Just picked up another standard made switch not too impressed with the way it's built.
Re: 71 Cuda ignition problem. [Re: NachoRT74] #2629878
03/07/19 08:42 AM
03/07/19 08:42 AM
N.y
W
Warrior Offline OP
Warrior  Offline OP
W
N.y
Just realize where you were located. I will be in Aruba for Flag Day. LOL
Re: 71 Cuda ignition problem. [Re: RapidRobert] #2629879
03/07/19 08:44 AM
03/07/19 08:44 AM
N.y
W
Warrior Offline OP
Warrior  Offline OP
W
N.y
Just picked up a new switch made by standard. We'll see
