Re: 71 Cuda ignition problem.
[Re: Warrior]
#2628482
03/03/19 11:28 PM
03/03/19 11:28 PM
RapidRobert
Yes, it makes up for Mr Murphy.
[Re: moparpoolman]
#2628491
03/03/19 11:46 PM
03/03/19 11:46 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
check / test ballast resistor Actually a damaged ballast won't start up ever if car is electronic ignition. Just will allow to fire up with points setup while cranking, but will stall when coming back to RUN
[Re: NachoRT74]
#2628516
03/04/19 12:23 AM
03/04/19 12:23 AM
RapidRobert
^^^ correct, ECU will not get fed in ign2 (crank)
[Re: Warrior]
#2628957
03/05/19 01:26 AM
03/05/19 01:26 AM
NachoRT74
Valencia, España
believe or not, I have replaced some parts on my car with used parts from JYs than looks somehow WAY BETTER than new replacements
[Re: NachoRT74]
#2628961
03/05/19 01:32 AM
03/05/19 01:32 AM
RapidRobert
Agreed quality is down but I think with another switch you will be OK. EDIT & if going to a yard is practical I think that would get you a good used one in hand.
