Tube or no Tube with slicks #2628636
03/04/19 12:41 PM
03/04/19 12:41 PM
Spanaway, Washington State
P
patosmith Offline OP
P
I'm getting ready to buy a set of slicks for my 72 Challenger.
28x10x15 in size going on a set of Jegs SSR Star wheels.
Challenger will race only a handful of times a year and will be in the mid to upper 11's.
Which is best? slicks that need tubes or tubeless?
Thanks for your help in advance.
Re: Tube or no Tube with slicks [Re: patosmith] #2628641
03/04/19 12:51 PM
03/04/19 12:51 PM
Findlay
Ramman Offline
Ramman  Offline
Findlay
If you're going to use beadlock rims or screws, I'd use tubes. If not, go tubeless. Your mileage may vary.
Re: Tube or no Tube with slicks [Re: patosmith] #2628645
03/04/19 12:54 PM
03/04/19 12:54 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I've run M/T, Goodyears and Hoosiers. I've run a 29x11.5 (11.50 car) and 31x14 (10.70 car) tire on my 2 cars (Dusters). I personally prefer the M/T with tubes. I've ran both cars with and without tubes and the cars run the same and are just as consistent, but for whatever reason my reaction times seem to be more consistent when I run tubes. I also think tubes help the sidewalls last longer as usually the sidewalls wear out before the "tread".
Re: Tube or no Tube with slicks [Re: patosmith] #2628654
03/04/19 01:13 PM
03/04/19 01:13 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I used to run tubes on my real slicks, I would put baby powder in the tires so as to not let tube stick to inside of tire. I also screwed the tires to the rims. With my street slicks like M+H's I ran tubeless but still screwed to the rim. Some friends would coat the inside of the tires with liquid dish soap claiming they had less leakage.
Ron
Re: Tube or no Tube with slicks [Re: patosmith] #2628711
03/04/19 03:27 PM
03/04/19 03:27 PM
an8sec70cuda Offline
I've always run tubes in slicks for two reasons. One is the tubes keep them from leaking. Two is the tube makes the sidewall stiffer which is faster and they last longer.
If you do run tubes, you HAVE to make sure the rim doesn't spin inside the tire or it can tear off the valve stem. I've always screwed them to the rim to prevent this from happening. You can also use hi-tack adhesive on the beads when you mount them, but screws are more secure IMO.
Baby powder on the tube when mounting the tire keeps the tube from getting folded up and "lubes" the tube inside the tire to keep it from rubbing.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Tube or no Tube with slicks [Re: patosmith] #2628715
03/04/19 03:36 PM
03/04/19 03:36 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I run Mickey Thompson slicks, their tech info says they will work better with tubes. I have always run tubes. As mentioned baby powder or corn starch so when the tire wrinkles it does not pinch the tube. And baby oil does work to keep them from leaking with out tubes, I use baby oil on my front tires.
Re: Tube or no Tube with slicks [Re: patosmith] #2628718
03/04/19 03:43 PM
03/04/19 03:43 PM
New Braunfels, TX
416challenger Offline
New Braunfels, TX
I run tubes also with my slicks. I like the additional stiffness for the sidewalls.
Re: Tube or no Tube with slicks [Re: patosmith] #2628736
03/04/19 04:15 PM
03/04/19 04:15 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I prefer tubes for the reasons already stated. The ones I use have a threaded stem so they're attached to the wheels. I also screw the slicks to the rims, both the inside & outside faces. I've run 'em as low as 6 PSI (as an experiment - no advantage found) on a low-10s Duster (13x31 slicks) and no problems.
Re: Tube or no Tube with slicks [Re: patosmith] #2628766
03/04/19 05:10 PM
03/04/19 05:10 PM
I use to race NHRA stock back before radial slicks where out, we always ran the bias ply slicks tubeless with screws in the rims to hold them onto the rims to prevent them sliding around.
I have ran the M/T Et Street bias ply tubelless as well as the same size M/T ET Street Radials, the radials where faster on a good track but would spin really bad on the street down
On your deal I would choose either Hoosiers or Good Year slicks in what ever their tech. guys reccomend on the construction, bias ply or radials, for your car and use scope
I think M/T is the only company still making tube type bias ply racing slicks shruggy scope
If you decide to run slicks they have to be true rubber racing tubes, not standard automotive local bought from a tire store cheap street tubes down tsk
All the drag race tire makers make stiff wall slicks for the cars that really need them scope
Re: Tube or no Tube with slicks [Re: patosmith] #2628906
03/04/19 11:29 PM
03/04/19 11:29 PM
P
P
Thanks for your input everyone!
I like M/T and I think I will get tubes with them.
I haven't thought of screws. Probably not a bad idea.
Thanks again!
Re: Tube or no Tube with slicks [Re: patosmith] #2628920
03/04/19 11:47 PM
03/04/19 11:47 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
No tubes and use Permatex on the bead. Also coat the inside with dish wash soap.
Re: Tube or no Tube with slicks [Re: patosmith] #2628987
03/05/19 02:30 AM
03/05/19 02:30 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
No tubes for me and I also don't run rim screws any more. My car can sit from December to late March and they don't leak any air. Ron
Re: Tube or no Tube with slicks [Re: patosmith] #2629262
03/05/19 04:14 PM
03/05/19 04:14 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
From Mickey Thompson's website regarding screws if you run a radial tire.
https://www.mickeythompsontires.com/drag-tires/racing-tubes#sizes
Also, the tubes such as what you get from MT, may require the rim's valve stem hole to be enlarged.
Re: Tube or no Tube with slicks [Re: RTSE4ME] #2629331
03/05/19 07:19 PM
03/05/19 07:19 PM
NE
moparpoolman Offline
NE
do you run screws? and can you or someone explain what to do with the permatex and the dish soap? thanks
Re: Tube or no Tube with slicks. [Re: patosmith] #2629355
03/05/19 08:32 PM
03/05/19 08:32 PM
The race tubes are really heavy, a lot heavier per tube than a regular car tube is!
Re: Tube or no Tube with slicks [Re: moparpoolman] #2629356
03/05/19 08:32 PM
03/05/19 08:32 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I haven't used a tube in any of my race cars for over 30 years.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Tube or no Tube with slicks [Re: pittsburghracer] #2629490
03/06/19 06:27 AM
03/06/19 06:27 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I ran no tubes for years. Wiping dish soap on the inner sidewalls (heavy coat) most times will keep them from leaking. Apply liberally with a sponge. Gluing the bead to the rim with purple Permatex keeps the tire from spinning on the rim. Works good. I now run tubes with Permatex. Been as quick as 1.24 60 ft. My car needed the extra stiffness provided by using a tube.
Doug
