Cable-operated throttle for warm-up, instead of choke?
#2627698
03/01/19 10:57 PM
03/01/19 10:57 PM
Posts: 1,074 So Cal, USA
Fab64
So Cal, USA
Hi all,
My car came with a six-pack induction system. For some reason, a previous owner milled down the choke tower on the center carb, so I don't have a choke. My climate is pretty mild, but I still sometimes need a little help during cold winter starts. I'm thinking about installing a cable-operated throttle, so I can increase engine rpm a bit during warm-up, then lower it back down to normal idle after a few minutes. Just curious to know if anyone here has done this, and how they went about it. Would also like to see what you used for cable, sources, etc. Thanks for any suggestions.
Roger
Re: Cable-operated throttle for warm-up, instead of choke?
[Re: Fab64]
#2627717
03/01/19 11:54 PM
03/01/19 11:54 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Cop spec M bodies had one from the factory.
Somewhere in a box I have a complete setup.
It essentially worked like a hand choke but instaed of operating the choke plate it operated the throttle.
[Re: Supercuda]
#2627730
03/02/19 12:24 AM
03/02/19 12:24 AM
Fab64
So Cal, USA
It essentially worked like a hand choke but instaed of operating the choke plate it operated the throttle. Years ago, I owned a '72 911 which had mechanical fuel injection. Between the seats, near the parking brake handle, was a hand-operated throttle for just that purpose. It was very handy, and worked great.
[Re: chargerbr549]
#2627808
03/02/19 07:16 AM
03/02/19 07:16 AM
Posts: 8,668 Buford, GA
I_bleed_MOPAR
Buford, GA
Tow trucks used to have a cable-operated throttle so you could increase line speed on the winch. Been a while since I drove one (pre-'84) but IIRC, you pulled the knob out (like a choke) to the desired speed then turned the knob clockwise to lock it. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: Fab64]
#2627827
03/02/19 10:45 AM
03/02/19 10:45 AM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
Had a 63 plymouth cop car that had a hand throttle to up RPMs.Was nice in winters warming it up.Rocky
Chrysler Firepower
[Re: chargerbr549]
#2627829
03/02/19 10:54 AM
03/02/19 10:54 AM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
Holley makes a idle kickup solenoid that I have used in the past, works really well and its adjustable on how much you want to open up the throttle. This is how I would do it with an electric solenoid like was used on many cars back in the 70's. Seen many Q-jets with them. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2627831
03/02/19 11:02 AM
03/02/19 11:02 AM
I_bleed_MOPAR
Buford, GA
Holley makes a idle kickup solenoid that I have used in the past, works really well and its adjustable on how much you want to open up the throttle. This is how I would do it with an electric solenoid like was used on many cars back in the 70's. Seen many Q-jets with them. Gus Those were GMs answer to run-on after switching the car off. It would work pretty well for what he wants to do, as well as the Holley solenoid chargerbr549 mentioned. Tim
[Re: Fab64]
#2627911
03/02/19 02:17 PM
03/02/19 02:17 PM
Posts: 5,443 Indiana
YO7_A66
Indiana
I use the Holley piece on a 4 barrel setup. Easy to adjust and mount.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#2627939
03/02/19 03:39 PM
03/02/19 03:39 PM
Fab64
So Cal, USA
I use the Holley piece on a 4 barrel setup. Easy to adjust and mount. Pretty clean. So, does the solenoid just move a set amount, but you can adjust where it starts? What type of switch do you use to turn it on from inside?
[Re: Fab64]
#2627953
03/02/19 04:17 PM
03/02/19 04:17 PM
YO7_A66
Indiana
When the solenoid is advanced, it holds the throttle open farther for a higher rpm. The hex can be adjusted by turning the hex (screw it in or out). Mine is controlled by the NSS. When the car is in P or N, the solenoid is retracted and the idle is controlled by the carb idle screw. When the car is in R, D, 2, or 1, the solenoid is extended. Setup this way allows me to have a higher idle rpm in the drive gears, and then when put in P or N, I have those rpms lower which helps it shut off without run-on.
[Re: Fab64]
#2628629
03/04/19 12:24 PM
03/04/19 12:24 PM
DaytonaTurbo
Manitoba, Canada
I have one on my jeep even though it's fuel injected. Some of us 4x4 guys with manual transmissions install them because it allows us to keep the rpm up while one foot is on the brake and one lets off the clutch when crawling, hill climbing, etc. The one I use is like a choke cable except it has a tee handle that turns to lock. Push in gas pedal, pull out cable, rotate handle clockwise 1/4 turns, let go of handle and pedal.
