brakes difference 7-1/4 & 8-3/4 axles #2625787
02/25/19 11:17 AM
02/25/19 11:17 AM
Madison, Wisconsin
chrisnben Offline OP
Madison, Wisconsin
Could a person use the backing plates and 10 x 2" brakes from a 7-1/4" rear to swap to a 8-3/4" all from E-body cars??
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
Re: brakes difference 7-1/4 & 8-3/4 axles [Re: chrisnben] #2625806
02/25/19 12:28 PM
02/25/19 12:28 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
When I swapped an 1966 8.75" housing into my car the brakes from the 7.25" it was replacing all transferred over. Didn't even need to change backing plates.
Re: brakes difference 7-1/4 & 8-3/4 axles [Re: chrisnben] #2625872
02/25/19 02:55 PM
02/25/19 02:55 PM
You might measure/compare (between the two) the shoe width area in the drums & the shoe width itself & the "offset" of the b plates. EDIT & axle flange distance out from b plate
Re: brakes difference 7-1/4 & 8-3/4 axles [Re: chrisnben] #2625877
02/25/19 03:06 PM
02/25/19 03:06 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
7 1/4 backing plates have 4 holes where the 8 3/4 plates have 5 holes.
Re: brakes difference 7-1/4 & 8-3/4 axles [Re: Pntastar69] #2625885
02/25/19 03:23 PM
02/25/19 03:23 PM
I ain't eyeballed em but would it be possible to drill the 5th hole in the retainer? (assuming everything else matched).
Re: brakes difference 7-1/4 & 8-3/4 axles [Re: chrisnben] #2625914
02/25/19 04:21 PM
02/25/19 04:21 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I replaced the 7 1/4 rear in an 82 Cordoba with an 8 3/4 and the brakes swapped right over.
Re: brakes difference 7-1/4 & 8-3/4 axles [Re: burdar] #2626105
02/25/19 11:33 PM
02/25/19 11:33 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Did same here with an 80 F body. Somewhere along the 7 1/4 line, dunno what year, the ends of housing changed to accept big hardware and 5 bolt retainers.
Re: brakes difference 7-1/4 & 8-3/4 axles [Re: chrisnben] #2626144
02/26/19 12:38 AM
02/26/19 12:38 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
My experience is that BBP brakes will interchange. E-body should be BBP.
Re: brakes difference 7-1/4 & 8-3/4 axles [Re: Pntastar69] #2626145
02/26/19 12:39 AM
02/26/19 12:39 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
the four holes line up, the fifth hole is redundant.
Don't be the exception.
Re: brakes difference 7-1/4 & 8-3/4 axles [Re: chrisnben] #2626148
02/26/19 12:45 AM
02/26/19 12:45 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
All 5 x 4.5" bolt pattern 7.25" rears have the same brakes as their 8.25", 8.75", 9.25" and 9.75" counterparts. The 5th hole in the backing plate is hidden behind the housing end flange.
