brakes difference 7-1/4 & 8-3/4 axles
#2625787
02/25/19 11:17 AM
02/25/19 11:17 AM
Posts: 1,033 Madison, Wisconsin
chrisnben
Madison, Wisconsin
Could a person use the backing plates and 10 x 2" brakes from a 7-1/4" rear to swap to a 8-3/4" all from E-body cars??
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
Re: brakes difference 7-1/4 & 8-3/4 axles
[Re: chrisnben]
#2625806
02/25/19 12:28 PM
02/25/19 12:28 PM
Posts: 4,421 Michigan
MarkZ
Worthy
Worthy
When I swapped an 1966 8.75" housing into my car the brakes from the 7.25" it was replacing all transferred over. Didn't even need to change backing plates.
[Re: chrisnben]
#2625872
02/25/19 02:55 PM
02/25/19 02:55 PM
RapidRobert
You might measure/compare (between the two) the shoe width area in the drums & the shoe width itself & the "offset" of the b plates. EDIT & axle flange distance out from b plate
[Re: Pntastar69]
#2625885
02/25/19 03:23 PM
02/25/19 03:23 PM
RapidRobert
I ain't eyeballed em but would it be possible to drill the 5th hole in the retainer? (assuming everything else matched).
[Re: chrisnben]
#2626144
02/26/19 12:38 AM
02/26/19 12:38 AM
Posts: 20,179 Park Forest, IL
slantzilla
Park Forest, IL
My experience is that BBP brakes will interchange. E-body should be BBP.
[Re: Pntastar69]
#2626145
02/26/19 12:39 AM
02/26/19 12:39 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
7 1/4 backing plates have 4 holes where the 8 3/4 plates have 5 holes. the four holes line up, the fifth hole is redundant.
