440 Will Not Start #2625456
02/24/19 02:40 PM
02/24/19 02:40 PM
FLPlum Offline OP
FLPlum  Offline OP
I guess I let it sit too long (3 months),
Priming the carb, it will start up no problem.
Then stops.
So I figure something like a fuel pump.
Anybody want to give me an idea and maybe some direction on finding the culprit.
I would rather fix myself than take to shop(flatbed).
All stock carter 4bbl.
Re: 440 Will Not Start [Re: FLPlum] #2625461
02/24/19 02:49 PM
02/24/19 02:49 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
I don't think that 3 months is really all that long. Maybe check fuel filter and pump operation first?
Scott
1969 Super Bee, 383/4 speed
Re: 440 Will Not Start [Re: FLPlum] #2625469
02/24/19 03:15 PM
02/24/19 03:15 PM
fill the bowl thru the vent till the AP will kick out a good squirt & fire it up. repeat if needed.
Re: 440 Will Not Start [Re: RapidRobert] #2625472
02/24/19 03:26 PM
02/24/19 03:26 PM
Wattsburg, Pa
Dr V Offline
Dr V  Offline
Wattsburg, Pa
If you think it is a fuel problem. Unhook the hard line that goes into the carburetor. Then put a great big old t-shirt underneath it. Disconnect the coil of course so that you get no spark. And have someone turn it over and crank it and see if you are getting the fuel pump pushing the fuel up to your carburetor. If you do then your carburetor line is not the problem.
69 1/2 A12 BEE 4 spd
1968 Charger 383
1970 Roadrunner 440+6 Survivor
2019 Redeye
2005 FORD GT Red/White
2017 Viper ACR Extreme Red/White
1979 Branco Red/Red
2018 Porsche GT3 Miami
1971 440+6 Cuda 4 speed V2
2020 Sebring Orange Vette
1979 Chevy Boogie Hippie Van
Re: 440 Will Not Start [Re: Dr V] #2625681
02/24/19 11:48 PM
02/24/19 11:48 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Good diagnostics but let's assume FLPlum has limited experience with this method.
We don't want sparks while we have fuel splashing onto a T shirt. So either jump 12 volts to the yellow wire on the starter relay or disconnect the coil or disconnect the ignition or ground the high tension lead to crank the engine.
If you absolutely can not find a suitable T shirt, run the fuel line into a container.
Re: 440 Will Not Start [Re: FLPlum] #2625685
02/24/19 11:53 PM
02/24/19 11:53 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Check the tank vent. They can get crusty when sitting. The pump can't overcome the vacuum. Take the gas cap off and prime the carb and start it.
Re: 440 Will Not Start [Re: FLPlum] #2625692
02/25/19 12:19 AM
02/25/19 12:19 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Floats can get stuck closed in the carb as well.
Re: 440 Will Not Start [Re: RTSrunner] #2625790
02/25/19 11:31 AM
02/25/19 11:31 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Or tank can be empty !
Re: 440 Will Not Start [Re: 62maxwgn] #2625855
02/25/19 02:24 PM
02/25/19 02:24 PM
moparx Offline
moparx  Offline
and over the [many] years, i fell for this malady more times than i care to admit ! and i was even sober ! laugh2
beer
Re: 440 Will Not Start [Re: FLPlum] #2625860
02/25/19 02:29 PM
02/25/19 02:29 PM
md
mopars4ever Offline
mopars4ever  Offline
md
If it turns out to be the fuel pump then check the length of the rod while you have it apart. They can wear down over time especially it if is a replacement one. I would also check every piece of rubber on the fuel line as the new gas seems to eat the old rubber up.
Re: 440 Will Not Start [Re: RTSrunner] #2625907
02/25/19 04:12 PM
02/25/19 04:12 PM
Cab_Burge Online work
Cab_Burge  Online Work
iagree hammer down lightly on the carb top above the floats to see if that will correct your problem scope
