440 Will Not Start
#2625456
02/24/19 02:40 PM
02/24/19 02:40 PM
FLPlum
I guess I let it sit too long (3 months), Priming the carb, it will start up no problem. Then stops. So I figure something like a fuel pump. Anybody want to give me an idea and maybe some direction on finding the culprit. I would rather fix myself than take to shop(flatbed). All stock carter 4bbl. Thanks
Re: 440 Will Not Start
[Re: FLPlum]
#2625461
02/24/19 02:49 PM
02/24/19 02:49 PM
Posts: 2,806 Northern NJ
StukaJU87
Northern NJ
I don't think that 3 months is really all that long. Maybe check fuel filter and pump operation first?
Scott
1969 Super Bee, 383/4 speed
[Re: FLPlum]
#2625469
02/24/19 03:15 PM
02/24/19 03:15 PM
RapidRobert
fill the bowl thru the vent till the AP will kick out a good squirt & fire it up. repeat if needed.
[Re: RapidRobert]
#2625472
02/24/19 03:26 PM
02/24/19 03:26 PM
Posts: 579 Wattsburg, Pa
Dr V
Wattsburg, Pa
If you think it is a fuel problem. Unhook the hard line that goes into the carburetor. Then put a great big old t-shirt underneath it. Disconnect the coil of course so that you get no spark. And have someone turn it over and crank it and see if you are getting the fuel pump pushing the fuel up to your carburetor. If you do then your carburetor line is not the problem.
69 1/2 A12 BEE 4 spd 1968 Charger 383 1970 Roadrunner 440+6 Survivor 2019 Redeye 2005 FORD GT Red/White 2017 Viper ACR Extreme Red/White 1979 Branco Red/Red 2018 Porsche GT3 Miami 1971 440+6 Cuda 4 speed V2 2020 Sebring Orange Vette 1979 Chevy Boogie Hippie Van
[Re: Dr V]
#2625681
02/24/19 11:48 PM
02/24/19 11:48 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
If you think it is a fuel problem. Unhook the hard line that goes into the carburetor. Then put a great big old t-shirt underneath it. Disconnect the coil of course so that you get no spark. And have someone turn it over and crank it and see if you are getting the fuel pump pushing the fuel up to your carburetor. If you do then your carburetor line is not the problem. Good diagnostics but let's assume FLPlum has limited experience with this method. We don't want sparks while we have fuel splashing onto a T shirt. So either jump 12 volts to the yellow wire on the starter relay or disconnect the coil or disconnect the ignition or ground the high tension lead to crank the engine. If you absolutely can not find a suitable T shirt, run the fuel line into a container.
