Page 1 of 5 1 2 3 4 5
Pinto Duster steering part 2 UPDATED 3-27-09 #262485
03/22/09 10:14 PM
03/22/09 10:14 PM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
My ex picked my daughter up this evening so I went out to tackle this steering job.
Well I have it mocked up and the tie rods come center with the steering arm holes. The suspension is pretty much unloaded, I know it will make some difference but this rack seems too long. Here's some pics.
Any Ideas????
Yes I know it's old school, but it's all I have for now.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Post deleted by Defbob [Re: DemonDust] #262486
03/22/09 10:24 PM
03/22/09 10:24 PM
Re: Pinto Duster steering part 2 #262487
03/22/09 10:33 PM
03/22/09 10:33 PM
Menomonee Falls
Menomonee Falls
very close to mine
There is no room for adjustment. Or did you bend the steering arms out?
Or should I say, Did Dave Christie and Herb Mc bend the steering arms out?
SDG Motorsports
Re: Pinto Duster steering part 2 [Re: DemonDust] #262488
03/22/09 11:05 PM
03/22/09 11:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Couple of important things to look at are, when you
have the suspension at curb height, is the rack level
with the steering arms... thats very important. You
also want the inner tie rod pivot to be in the same
plane as the inner lower control arm pivot... these
2 things minimize toe change during suspension travel
EDIT
On the length, just cut it shorter and re thread it,
but do that later when you have everything in the
proper location, will the tie rods be on top or bottom
of the steering arms
Re: Pinto Duster steering part 2 [Re: MR_P_BODY] #262489
03/22/09 11:14 PM
03/22/09 11:14 PM
Menomonee Falls
Menomonee Falls
So at ride height the rack and tie rods should be straight across?
The ball and socket is very close to if not in line with the lower control arm pivot
SDG Motorsports
Re: Pinto Duster steering part 2 [Re: MR_P_BODY] #262490
03/22/09 11:21 PM
03/22/09 11:21 PM
Menomonee Falls
Menomonee Falls
EDIT
Well at ride height it looks like the tie rods will be below the steering arm.
SDG Motorsports
Re: Pinto Duster steering part 2 [Re: DemonDust] #262491
03/22/09 11:21 PM
03/22/09 11:21 PM
Northeast, Arkansas
Dodgeman67 Offline
Dodgeman67  Offline
Northeast, Arkansas
The lower control arm and the steering arm should be parrallel, that keeps you from having bump steer.
Re: Pinto Duster steering part 2 [Re: DemonDust] #262492
03/22/09 11:22 PM
03/22/09 11:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes you want the rack in line/level with the outer
tie rod ends. The closer you can get the inner tie rod
ball and socket to the height and in/out distance of
the inner lower control arn pivot the better, it can
be forward but the up/down and in/out are important
Re: Pinto Duster steering part 2 [Re: DemonDust] #262493
03/22/09 11:23 PM
03/22/09 11:23 PM
Menomonee Falls
Menomonee Falls
What is the difference between the A-body steering arms and B-body steering arms?
SDG Motorsports
Re: Pinto Duster steering part 2 [Re: MR_P_BODY] #262494
03/22/09 11:27 PM
03/22/09 11:27 PM
merrill, wisconsin
V
voigtspeed Offline
voigtspeed  Offline
V
merrill, wisconsin
Hey jesse
racks way too low and those brakes and wheel adapters are scary.
As much as you have cut away already maybe go with some mustang II stuff CHEAP and lots of aftermarket brake options.
or do up a strut suspension cant tell from pictures how low your engine sits as far as how much you can raise the rack but as stated the rack must go up to have the right arc travel also if you swap spindles left to right you mess with the camber to get that back you have to move your lower or uper control arm mounting points .
its not a real quick bolt in to do it right not real hard but anyway you do it it wll take some time and fabing and meausuring.
unless you open the wallet for aftermarket bolt in suspension..
been real bussy but give me a call maybe i can walk you through it.
jim
ACCELERATION SPECIALIST
Re: Pinto Duster steering part 2 [Re: voigtspeed] #262495
03/22/09 11:39 PM
03/22/09 11:39 PM
Menomonee Falls
Menomonee Falls
Hey jesse
jim
I never moved the spindles. Just swapped lower ball joints.
I have all the time in the world right now for fabbing and measuring. Moving the rack up is no problem.
Money is tight for anything but stock. I looked at the mustang II stuff your still looking at around $400-500 by the time your done. Unless I'm looking at the wrong stuff.
I really don't want to cut much more, because I will be interfering with the forward support rods in the front and torsion bars in the rear.
As far as an after market setup, NO WAY i can shovel out $3500-4000 for one right now.
If anyone has any parts to donate feel free to send them my way
Re: Pinto Duster steering part 2 [Re: DemonDust] #262496
03/23/09 01:35 AM
03/23/09 01:35 AM
Menomonee Falls
Menomonee Falls
Ok did some measuring and blueprinting in my head
The rack can be moved up 4-5", but at ride height it looks like it will only have to be moved up about 3". I'll radius out the 2x4" tubing I have tacked in there for the rack and that will make plenty of room.
Mr P how did you cut and rethread your tie rods? The reason I ask is the dia of the rod is much too big to just run a die over. The only thing I can see is to remove the ball and socket from the rack and turn in a lathe.
My other question is, the drivers side has a plate with two mounting holes. There is nothing on the passenger side to mount. It's just a smooth housing. How do you mount this side?
SDG Motorsports
Post deleted by Defbob [Re: DemonDust] #262497
03/23/09 03:45 AM
03/23/09 03:45 AM
Re: Pinto Duster steering part 2 #262498
03/23/09 08:00 AM
03/23/09 08:00 AM
Northeast, Arkansas
Dodgeman67 Offline
Dodgeman67  Offline
Northeast, Arkansas
Jesse, they make a kit that has sleeves that slides over your steering arms on the rack, and it has hymes with it to bolt your steering arms to.
We did ours last year and here are a couple pictures.
Re: Pinto Duster steering part 2 [Re: Dodgeman67] #262499
03/23/09 08:27 AM
03/23/09 08:27 AM
the house on the left.
cogen80 Offline
cogen80  Offline
hey fred. your lower arm on opposite sides?
Re: Pinto Duster steering part 2 [Re: DemonDust] #262500
03/23/09 01:45 PM
03/23/09 01:45 PM
Menomonee Falls
Menomonee Falls
Wow
Jeff you really have your rack way up front. If I moved mine that far forward I dont think I'd have any problems.
I could easily get the rack at the right elevation. Will the tie rods being angled back like that effect anything?
SDG Motorsports
Re: Pinto Duster steering part 2 [Re: DemonDust] #262501
03/23/09 05:58 PM
03/23/09 05:58 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Whar spindle's/ball joints do you have dodgeman ?
Re: Pinto Duster steering part 2 [Re: VernMotor] #262502
03/23/09 06:02 PM
03/23/09 06:02 PM
Menomonee Falls
Menomonee Falls
What is more important?
1. Having the rack level with the steering arms
or
2. Having the ball and socket at proper elevation and in line with lower control arm pivot.
It has to be one or the other. Looking at it, I can't do both.
SDG Motorsports
Re: Pinto Duster steering part 2 [Re: DemonDust] #262503
03/23/09 06:31 PM
03/23/09 06:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
or
You really need to do both... either one can change
the toe curve during the travel
Re: Pinto Duster steering part 2 [Re: VernMotor] #262504
03/23/09 06:41 PM
03/23/09 06:41 PM
Northeast, Arkansas
Dodgeman67 Offline
Dodgeman67  Offline
Northeast, Arkansas
Their strange struts.
We put all that on last year at this time, there is a build up on here somewhere of it.
