87 K Car Weather Stripping #2623074
02/18/19 09:59 PM
02/18/19 09:59 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline OP
elmor353  Offline OP
E
Having trouble finding door and window channel weather stripping for my 87 New Yorker. RockAuto doesn't seem to have anything and I've tried several other online sources with no results. Went to my local Chrysler dealership and they laughed at me. The parts guy said they hadn't seen one of those cars in 20 years. Any ideas would be greatly appreciated.
Re: 87 K Car Weather Stripping [Re: elmor353] #2623132
02/18/19 11:50 PM
02/18/19 11:50 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
If you still have a small chunk of the original stuff, you can make a cut to get a cross section side view of the original stuff. The original weather stripping was probably used on a bunch of vehicles during the time period your K car was built. Most weatherstripping companies have pictures of the side view for the weatherstripping they carry, in real life size. They usually sell it by the foot. Match your end view to the closest thing they offer, determine how many feet of it you need and order it. When you get it, clean off the old stuff, clean the mounting surface on the new stuff, use 3m weather stripping glue on both surfaces and glue the new stuff on your car just like the old stuff used to be. Gene
Re: 87 K Car Weather Stripping [Re: poorboy] #2623168
02/19/19 01:01 AM
02/19/19 01:01 AM
E
elmor353 Offline OP
elmor353  Offline OP
E
Thank you for your suggestion. I have 1 door that's missing about 6 inches of rubber and window channel insulation. They probably used the same rubber on a bunch of models in that time period.
Re: 87 K Car Weather Stripping [Re: elmor353] #2623193
02/19/19 02:31 AM
02/19/19 02:31 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Check with Marty at Arizona Parts - he might have NOS.
Re: 87 K Car Weather Stripping [Re: elmor353] #2623269
02/19/19 12:33 PM
02/19/19 12:33 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If nothing else, try turbododge.com or turbo-mopar.com for someone parting out a car. Or you might find a wrecker parting out one over on car-part.com
Re: 87 K Car Weather Stripping [Re: elmor353] #2623322
02/19/19 02:45 PM
02/19/19 02:45 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I found two on ebay. I can tell you how to find it, but you have to call me, I'm not gonna write a book on here.
423-312-6962
Re: 87 K Car Weather Stripping [Re: 71birdJ68] #2623893
02/20/19 08:10 PM
02/20/19 08:10 PM
E
elmor353 Offline OP
elmor353  Offline OP
E
I found the 2 on ebay as well. Still don't know that it's what I'm looking for and I'm not willing to spend $125 to find out it's not. I may just cut out a sample and run down to the local pick a part and see if I can match it up with something.
Re: 87 K Car Weather Stripping [Re: elmor353] #2623930
02/20/19 09:57 PM
02/20/19 09:57 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Did you read my post?
Re: 87 K Car Weather Stripping [Re: 71birdJ68] #2623956
02/20/19 10:38 PM
02/20/19 10:38 PM
E
elmor353 Offline OP
elmor353  Offline OP
E
Thank you 71birdJ68 for your help today. It is much appreciated.
Re: 87 K Car Weather Stripping [Re: elmor353] #2623994
02/20/19 11:56 PM
02/20/19 11:56 PM
New Jersey
P
Powerflow Offline
Powerflow  Offline
P
New Jersey
You might have better luck if you could pin down the exact factory part numbers you need, then use those numbers in a search.
