fan recommendation #2622683
02/17/19 08:37 PM
02/17/19 08:37 PM
Garry Owen Offline OP
Want to switch a fixed fan to clutch style. Have 3 3/4" between snout and radiator. The spacer that's on it now allows the blades to just barely hit the power steering shaft also.
Would I be better of with a clutch fan or just find a spacer 1/4" longer a keep the fixed? Is parasitic loss or the cfm moved matter that much to switch between the two?
Re: fan recommendation [Re: Garry Owen] #2622715
02/17/19 10:23 PM
02/17/19 10:23 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Shortest clutch I know of, specs in the link
Jag clutch
This one is a bit taller
Other Jag clutch
Of course you will need a new fam, buy on a bit smaller in diameter to clear your P/S.
Don't be the exception.
Re: fan recommendation [Re: Garry Owen] #2622759
02/18/19 12:15 AM
02/18/19 12:15 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
2947 hayden is a new HD short clutch for a Mopar
CLICK HERE
Re: fan recommendation [Re: Garry Owen] #2622769
02/18/19 12:35 AM
02/18/19 12:35 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The short Jag one is still shorter and the 2947 isn't specifically for mopars either.
Re: fan recommendation [Re: Garry Owen] #2623009
02/18/19 06:30 PM
02/18/19 06:30 PM
Thanks.
Re: fan recommendation [Re: Garry Owen] #2623080
02/18/19 10:08 PM
02/18/19 10:08 PM
IN
ahy Offline
ahy  Offline
IN
The clutch fan is quieter and safer. The clutch acts as speed governor to an extent and reduces chance of blades coming apart. Hopefully one of those clutches works for you.
