Re: fan recommendation
[Re: Garry Owen]
#2622715
02/17/19 10:23 PM
02/17/19 10:23 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Shortest clutch I know of, specs in the link Jag clutch This one is a bit taller Other Jag clutch Of course you will need a new fam, buy on a bit smaller in diameter to clear your P/S.
[Re: Garry Owen]
#2622759
02/18/19 12:15 AM
02/18/19 12:15 AM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
2947 hayden is a new HD short clutch for a Mopar CLICK HERE
[Re: Garry Owen]
#2622769
02/18/19 12:35 AM
02/18/19 12:35 AM
Supercuda
About to go away
About to go away
up yours
The short Jag one is still shorter and the 2947 isn't specifically for mopars either.
[Re: Garry Owen]
#2623009
02/18/19 06:30 PM
02/18/19 06:30 PM
Garry Owen
