adj rocker stock v.c. fit #2622055
02/16/19 11:50 AM
02/16/19 11:50 AM
calsfunrides Offline OP
putting together max wedge need to find a good quality reasonable price adjustable rocker assy. to fit under stock valve covers thanks.
Re: adj rocker stock v.c. fit [Re: calsfunrides] #2622072
02/16/19 12:14 PM
02/16/19 12:14 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Re: adj rocker stock v.c. fit [Re: TooMany62s] #2622097
02/16/19 01:04 PM
02/16/19 01:04 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Or you can make them fit !
Re: adj rocker stock v.c. fit [Re: calsfunrides] #2622143
02/16/19 02:57 PM
02/16/19 02:57 PM
Are your current valve covers original max wedge or not?
If not then you may need to do the mods already posted to get the adjusters to clear the stock baffles in the OEM valve covers for stock stamp steel rockers scope
As far as finding a good quality set of rocker arms to CLEAR stock covers probably no such thing out there shruggy
When I first started racing, hot rodding and building Mopar V8 back in the early 1960 most people used adjustable pushrods for making a motor with solid lifters that didn't come with adjustable rocker arms work
They are a pain to use and adjust though whiney work
Re: adj rocker stock v.c. fit [Re: Cab_Burge] #2622153
02/16/19 03:17 PM
02/16/19 03:17 PM
They are AMD application for max wedge. I have heard about reaming holes out in the baffles and did not know if that was done just for the ductal iron rockers. I have found crane cam ductal units at summit did not know if they would fit.
Re: adj rocker stock v.c. fit [Re: Cab_Burge] #2622157
02/16/19 03:22 PM
02/16/19 03:22 PM
IN
ahy Offline
ahy  Offline
IN
The OE type adjustable iron rockers in the ad above or Comp "pro magnum" investment cast alloy steel are probably as compact as anything out there. Both good solid rockers.
Re: adj rocker stock v.c. fit [Re: ahy] #2622163
02/16/19 03:35 PM
02/16/19 03:35 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And for what it's worth,the original Chrysler adjustable rockers are no a true 1.5 ratio.
Re: adj rocker stock v.c. fit [Re: 62maxwgn] #2622180
02/16/19 04:11 PM
02/16/19 04:11 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Thicker gaskets, double gaskets or valve cover spacers might be other options
SPACERS LINKY
beer
Re: adj rocker stock v.c. fit [Re: calsfunrides] #2622251
02/16/19 06:56 PM
02/16/19 06:56 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
The adjuster is what contacts the VC baffle on some rockers. The shorter and compact the adjuster, the better your chances of not having to modify the VC. Obviously, cam lift plays a role too.
Re: adj rocker stock v.c. fit [Re: calsfunrides] #2622262
02/16/19 07:18 PM
02/16/19 07:18 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
You can double up on the super thick mopar vc gaskets - the ones that come with their aluminum covers.
Re: adj rocker stock v.c. fit [Re: calsfunrides] #2622284
02/16/19 08:08 PM
02/16/19 08:08 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't be the exception.
Re: adj rocker stock v.c. fit [Re: calsfunrides] #2622298
02/16/19 08:58 PM
02/16/19 08:58 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
I use Crane ductile iron rockers in my 493 stroker, have had stock mopar v- covers with them.. they work great... had them on for years now,Now I have polished alum covers , but the stock ones clear with no problem..
Re: adj rocker stock v.c. fit [Re: Supercuda] #2622353
02/16/19 11:05 PM
02/16/19 11:05 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I used the spacers from Medice on my 340 for two reasons. I needed the space and I was having oil leaks using my stock valve covers. These spacers took care of both issues.
Re: adj rocker stock v.c. fit [Re: calsfunrides] #2622363
02/16/19 11:24 PM
02/16/19 11:24 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not cheap, but then again not cheaply made. Quality costs.
Re: adj rocker stock v.c. fit [Re: calsfunrides] #2622417
02/17/19 01:51 AM
02/17/19 01:51 AM
The original max wedge valve covers, both the 4 and 6 bolt versions, fit most every adjustable rocker arm out there with no hitting up
