Re: adj rocker stock v.c. fit
[Re: calsfunrides]
#2622143
02/16/19 02:57 PM
02/16/19 02:57 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
Are your current valve covers original max wedge or not? If not then you may need to do the mods already posted to get the adjusters to clear the stock baffles in the OEM valve covers for stock stamp steel rockers As far as finding a good quality set of rocker arms to CLEAR stock covers probably no such thing out there When I first started racing, hot rodding and building Mopar V8 back in the early 1960 most people used adjustable pushrods for making a motor with solid lifters that didn't come with adjustable rocker arms They are a pain to use and adjust though
[Re: Supercuda]
#2622353
02/16/19 11:05 PM
02/16/19 11:05 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
I used the spacers from Medice on my 340 for two reasons. I needed the space and I was having oil leaks using my stock valve covers. These spacers took care of both issues.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: calsfunrides]
#2622363
02/16/19 11:24 PM
02/16/19 11:24 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Not cheap, but then again not cheaply made. Quality costs.
