1969 barracuda stripe #2593122
12/17/18 01:27 PM
12/17/18 01:27 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
Looking for detail information for factory stripes for a 1969 barracuda. Like stripe height and placement. I will be sending my car to be painted in the next month or so hopefully and would like to have the factory stripe painted on with the 340 call outs.
Re: 1969 barracuda stripe [Re: DusterKid] #2593221
12/17/18 04:11 PM
12/17/18 04:11 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
This is the placement info from Performance Car Graphics where you can buy the stripe with 340/383 callout.
The actual width of the stripe is 3-15/16" with two 5/16" narrow parts.
[img]https://beta-static.photobucket.com/imag...&fit=bounds[/img]
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: 1969 barracuda stripe [Re: RealWing] #2593237
12/17/18 04:32 PM
12/17/18 04:32 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
do the "340" emblems go away on '69 Barracudas with the sport stripes?
does it matter if it is a Formula S or STANDARD Barracuda?
are the above PCG reference pics a 318 or /6 car? do all 340/383 cars with sport stripes have the "340"/'383" callout? (non-'cuda)
Re: 1969 barracuda stripe [Re: DusterKid] #2593411
12/17/18 10:36 PM
12/17/18 10:36 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
The "Sports Stripes" were not available if the "Accent Stripes" (the 2 thin lines) were ordered.
The Sports Stripes came in black, red or white with 340 or 383 callouts if you ordered that engine. They also came with no engine callout. They were available with or without Formula S package.
They were not available if you ordered the "Cuda 340" or "Cuda 383" option
Re: 1969 barracuda stripe [Re: RealWing] #2595577
12/22/18 07:25 PM
12/22/18 07:25 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
That’s is the information I used when I applied mine.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: 1969 barracuda stripe [Re: DusterKid] #2597686
12/27/18 06:36 PM
12/27/18 06:36 PM
Port Saint Lucie, FL
ChallengerGary Offline
I can make a paint mask kit for you if you want them to be exact.
Re: 1969 barracuda stripe [Re: ChallengerGary] #2619703
02/11/19 11:04 AM
02/11/19 11:04 AM
Keymar, MD
Keymar, MD
Finally got the car painted on Saturday. Stripe isn't 100% per factory, but pretty close and turn out well. Thanks for everyone that commented with info that helped me with this.
Re: 1969 barracuda stripe [Re: DusterKid] #2619802
02/11/19 02:29 PM
02/11/19 02:29 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Looking good!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: 1969 barracuda stripe [Re: DusterKid] #2621130
02/14/19 03:28 AM
02/14/19 03:28 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Looks just like my F-5 '69 coupe! Or is yous F8? The stripe looks factory correct to me, except too shiny for vinyl and it should terminate in the rear about 3/4" to 1" from the tail light.
If you ordered Formula S, you got the stripes unless you ordered stripe delete.
This photo shows the factory vinyl stripe on original factory paint without the tail light.
Re: 1969 barracuda stripe [Re: kentj340] #2621174
02/14/19 10:35 AM
02/14/19 10:35 AM
Keymar, MD
Keymar, MD
The car is F5, just the lighting from that picture make it look darker than what it is. We ended the stripe 1/4" from the end, so we were off a little bit there.
Here's a pic of the green inside before the clear was applied.
Re: 1969 barracuda stripe [Re: DusterKid] #2621544
02/15/19 03:53 AM
02/15/19 03:53 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Fantastic. Looks great. Aiming to copy what you've done soon.
Re: 1969 barracuda stripe [Re: kentj340] #2622816
02/18/19 03:29 AM
02/18/19 03:29 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
I measured the gap between the end of the vinyl stripe and the end of the fender. 11/16” one side, 9/16” the other side. So the gap was 5/8” +/- 1/16”.
