Re: 1969 barracuda stripe
[Re: DusterKid]
#2593411
12/17/18 10:36 PM
12/17/18 10:36 PM
Posts: 315 Ontario, Canada
RealWing
Ontario, Canada
The "Sports Stripes" were not available if the "Accent Stripes" (the 2 thin lines) were ordered. The Sports Stripes came in black, red or white with 340 or 383 callouts if you ordered that engine. They also came with no engine callout. They were available with or without Formula S package. They were not available if you ordered the "Cuda 340" or "Cuda 383" option
1970 Superbird 440-6bbl, auto 1969 Barracuda 340-4bbl, FB Formula S auto 1969 Barracuda 6.1 L Hemi, 5 speed, Convertible 2022 Can Am Spyder RTL
[Re: RealWing]
#2595577
12/22/18 07:25 PM
12/22/18 07:25 PM
Posts: 16,487 On the run…
BloFish
On the run…
That’s is the information I used when I applied mine.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: DusterKid]
#2621130
02/14/19 03:28 AM
02/14/19 03:28 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Looks just like my F-5 '69 coupe! Or is yous F8? The stripe looks factory correct to me, except too shiny for vinyl and it should terminate in the rear about 3/4" to 1" from the tail light.
If you ordered Formula S, you got the stripes unless you ordered stripe delete.
This photo shows the factory vinyl stripe on original factory paint without the tail light.
[Re: DusterKid]
#2621544
02/15/19 03:53 AM
02/15/19 03:53 AM
kentj340
Cut and Shoot, TX
Fantastic. Looks great. Aiming to copy what you've done soon.
[Re: kentj340]
#2622816
02/18/19 03:29 AM
02/18/19 03:29 AM
kentj340
Cut and Shoot, TX
I measured the gap between the end of the vinyl stripe and the end of the fender. 11/16” one side, 9/16” the other side. So the gap was 5/8” +/- 1/16”.
