8 3/4 rear end #2619775
02/11/19 01:39 PM
02/11/19 01:39 PM
Chicago land, IL
dafixr Offline OP
dafixr  Offline OP
Chicago land, IL
how much power do u think i can throw at a 8 3/4 rear end . right now its a high 9sec car. makes about 650 to 700hp right now. car is a 71 dart
Re: 8 3/4 rear end [Re: dafixr] #2619779
02/11/19 01:47 PM
02/11/19 01:47 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
About 5-6 Cylinders in your case. stirthepot
Re: 8 3/4 rear end [Re: dafixr] #2619796
02/11/19 02:22 PM
02/11/19 02:22 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
YOUR AT THE LIMIT NOW....
....BAD A$$ STREET CAR.....
Re: 8 3/4 rear end [Re: dafixr] #2619801
02/11/19 02:29 PM
02/11/19 02:29 PM
Rochester, PA (near Pittsburgh...
1974 474 Duster Offline
My car started hitting regularly low 1.30 60' times. It started the eat ring gears. Now I did have a big tire car, but still. I agree your 8 3/4 is about where it's going to start breaking parts on a regular basis.
Thanks, Ken
Re: 8 3/4 rear end [Re: dafixr] #2619859
02/11/19 04:06 PM
02/11/19 04:06 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
High 9s at 650HP. It's no lightweight. I'm surprised you haven't broken it already unless you don't have many runs on it. Just sayin'
Re: 8 3/4 rear end [Re: dafixr] #2619862
02/11/19 04:12 PM
02/11/19 04:12 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Take it out now, while you can still sell it.
Boffin Emeritus
Re: 8 3/4 rear end [Re: dafixr] #2619864
02/11/19 04:14 PM
02/11/19 04:14 PM
Kirkland, Washington
Pacnorthcuda Offline
The unit you are running must be set up real well, and you must launch pretty darn well too!
Congrats, that's impressive. You need a Dana or a GOOD Nine, (the only Ford part worth a crap)
Re: 8 3/4 rear end [Re: dafixr] #2619880
02/11/19 04:42 PM
02/11/19 04:42 PM
yarnell,az
mopacltd Offline
mopacltd  Offline
yarnell,az
Axle tube flex is a determining factor. Is the housing back braced and how wide is it?
Re: 8 3/4 rear end [Re: dafixr] #2619948
02/11/19 07:31 PM
02/11/19 07:31 PM
Chicago land, IL
dafixr Offline OP
dafixr  Offline OP
Chicago land, IL
car 60fts 1.30's - 1.40s depending on the track. its a nitrous car also with small 150 shot. so it leaves pretty damn good. we normally run a 10.20 index but wanna turn it up and go to a faster class just trying to see if the rear end should go or can we still beat on it. seems like it needs to go
Re: 8 3/4 rear end [Re: dafixr] #2619978
02/11/19 08:34 PM
02/11/19 08:34 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
That's a good looking race car.
I'd take steps to try and keep it that way.
Re: 8 3/4 rear end [Re: dafixr] #2620148
02/12/19 03:21 AM
02/12/19 03:21 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
When I first started racing the Duster it had a 600 horse 440 that I foot braked. The car weighed approximately 3400 with me in it. The 8 3/4 was fine for that season. We installed a trans brake over the winter. The first launch with the trans brake we broke the ring and pinion! Alot of factors go into longevity of a particular part. Weight, HP, launch style etc......If you can afford it put a Dana 60 in it. Knowing what I know now I wish I had went Dana from the start. I hate spending money twice! This sport is expensive enough as it is.
Re: 8 3/4 rear end [Re: polyspheric] #2620210
02/12/19 11:32 AM
02/12/19 11:32 AM
an8sec70cuda Offline
iagree
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 8 3/4 rear end [Re: polyspheric] #2620561
02/12/19 11:25 PM
02/12/19 11:25 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Truth
"Just a Bracket car dressed up like a streetcar"
Re: 8 3/4 rear end [Re: Just-a-dart] #2620604
02/13/19 01:11 AM
02/13/19 01:11 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
My Son has 3 years on the 4.10's in his 8 3/4 that were set up by Tim Bowman of Bowman Performance. It ran 10'0's for awhile with my 408 and now 6.54 (10.20-10.30's) with his stock crank 360. Its a 727 with trans-brake car. Since our class now runs 1/8 mile at every track he may step up to a 4.56 gear for 2019. It leaves pretty hard.
Untitled by John Cadamore, on Flickr
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 8 3/4 rear end [Re: dafixr] #2620636
02/13/19 02:27 AM
02/13/19 02:27 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
35 spline John? We ran 30 spline when my dad had the Duster. We were twisting the daylights out of axles, that’s when we quit spending money on that venture.
Re: 8 3/4 rear end [Re: dafixr] #2620730
02/13/19 12:16 PM
02/13/19 12:16 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
. 8 3/4 I’ve been thinking the same thing
