Page 1 of 5 1 2 3 4 5
73 Charger running NOW!!! All help appreciated #2619920
02/11/19 06:19 PM
02/11/19 06:19 PM
Martinsville, IN
cdwmotorsports Offline OP
Martinsville, IN
https://www.dropbox.com/s/pcqefbefh9kuais/Video%20Feb%2011%2C%2014%2037%2033.mp4?dl=0
So it’s stated it’s carb cleaner not starting fluid I’m spraying in the carb to get it to fire.
This is a link to the video of what I’m dealing with right now. This 73 Charger was put away at least 10 years ago maybe 13 in the same state I have it right now. I know it has a vacuum cap missing on the metering block. I just put the FBO ignition on it today hoping that it would just fire up but all I get is the stuttering. I think I’m gonna pull the distributor cap and check the gap. The fuel pump is currently not running as I pulled the fuel line off it to ensure I don’t get any garbage in it. Any other ideas what I should look for?
eBay-cdwmotorsports
Re: 73 Charger won’t run, any help appreciated [Re: cdwmotorsports] #2619954
02/11/19 07:41 PM
02/11/19 07:41 PM
Chicago
PurpleBeeper Offline
Chicago
I'd suggest you change ALL the fuel in the car (gasoline goes bad in about 6 months) and go back to basics. Check your firing order, distributor rotation, cap/rotor/plugs. Best of Luck!
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: 73 Charger won’t run, any help appreciated [Re: cdwmotorsports] #2619976
02/11/19 08:32 PM
02/11/19 08:32 PM
Martinsville, IN
Martinsville, IN
I disconnected the fuel pump so it had no power. That was trying to run on straight carb cleaner. I didn’t even think about firing order. My parents let my ex brother in law jack with it so who knows what all isn’t right. Today I found the carb wasn’t bolted down.
eBay-cdwmotorsports
Re: 73 Charger won’t run, any help appreciated [Re: cdwmotorsports] #2619985
02/11/19 08:40 PM
02/11/19 08:40 PM
N.W. Florida
Fat_Mike Online work
Fat_Mike  Online Work
N.W. Florida
Are you simply trying to make sure it WILL run at this point? I've never used carb cleaner that a car would/could run on (solely). I would suggest you put some gas in something akin to a ketchup squirt bottle and have someone slowly squirt THAT into the carb while you're cranking.
Re: 73 Charger won’t run, any help appreciated [Re: Fat_Mike] #2620010
02/11/19 09:52 PM
02/11/19 09:52 PM
I'd fill the carb bowl with (fresh) gas & run the pump inlet into a can of (fresh) gas & cap the carb nipple & I would preoil it after all this time & oil the cyls. I'm assuming it ran when parked so I would disable the starter (pull the yellow wire at the starter relay) & see if your connections are correct & everything is being fed in "crank" & "run" that should be. I'm assuming the dist has been moved so confirm basic timeing (15 BTDC is good)
Re: 73 Charger won’t run, any help appreciated [Re: RapidRobert] #2620029
02/11/19 10:46 PM
02/11/19 10:46 PM
Martinsville, IN
Martinsville, IN
It did not run when parked. My ex brother in law drove it, f-Ed it up and assured my parents he could fix it. He didn’t fix it and it has sat 10-13 years in a barn untouched. When I got it off the trailer after buying it from my parents and dragging it home I replaced the battery, ignition box and coil (now FBO stuff), and bypassed the ballast resistor. I bought new fuel filters and fuel line to ensure it’s not got fuel issues too, those have not been put on and I didn’t have the fuel pump turned on to avoid junking the carb, pump or regulator.
eBay-cdwmotorsports
Re: 73 Charger won’t run, any help appreciated [Re: cdwmotorsports] #2620060
02/11/19 11:53 PM
02/11/19 11:53 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
It may be wrong to assume that you have oil in, and an oil filter on the motor? Spin the oil pump to prime the oil system.
I'd bring #1 up on compression and make sure it didn't jump the timing chain.
Pull the plugs ans put a little oil into each cylinder, then spin the motor over with the starter. Bring # 1 back up on compression, install new plugs, and be sure the ignition wires are connected to the proper cylinders, in the proper rotation, and in the proper position. Check for spark. If you have compression, spark at the right place at the right time, all you should need is fuel, use gas. Fill the carb float bowl and try to start it. Gene
Re: 73 Charger won’t run, any help appreciated [Re: poorboy] #2620070
02/12/19 12:13 AM
02/12/19 12:13 AM
Martinsville, IN
Martinsville, IN
Why would you assume it doesn’t have oil or a filter? 30 years of messing with cars, it has oil.
eBay-cdwmotorsports
Re: 73 Charger won’t run, any help appreciated [Re: cdwmotorsports] #2620114
02/12/19 01:38 AM
02/12/19 01:38 AM
I may have missed something but I would start from scratch & change oil/filter & drill prime it. oil the cyls. check/clean plugs. confirm the ign connections (while you are priming, good opportunity to spin the dist by hand & see if it sparks at the plug wires). fill the carb bowl. gas to pump inlet. clean large cables/terminals (including ground paths) for good cranking. static time at 15 BTDC compression. cap the open carb nipple. EDIT & get the crank on #6 TDC compression & preoil then go CCW 3/4 of a turn (to #8 TDC compression) & preoil again to oil both heads. easiest is get rotor at #8 before you even pull the dist then preoil there then come forward CW till the marks are at TDC on the tab (3/4 turn) at #6 TDC compression & preoil again
Re: 73 Charger won’t run, any help appreciated [Re: cdwmotorsports] #2620116
02/12/19 01:43 AM
02/12/19 01:43 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Why? What's wrong with the stock ignition?
John
Re: 73 Charger won’t run, any help appreciated [Re: SattyNoCar] #2620139
02/12/19 02:38 AM
02/12/19 02:38 AM
Martinsville, IN
Martinsville, IN
The stock ignition was all junk replacement parts bought from autozone or some other crap box auto parts store! Because my ex BIL is a cheapskate and doesn’t ever do anything right.
eBay-cdwmotorsports
Re: 73 Charger won’t run, any help appreciated [Re: cdwmotorsports] #2620140
02/12/19 02:40 AM
02/12/19 02:40 AM
Martinsville, IN
Martinsville, IN
The open carb nipple is from the vacuum advance being off of it. Fixed that already
eBay-cdwmotorsports
Re: 73 Charger won’t run, any help appreciated [Re: cdwmotorsports] #2620216
02/12/19 12:03 PM
02/12/19 12:03 PM
SattyNoCar Offline
SattyNoCar  Offline
Is it installed correctly? IE: did you wire it up correctly?
Installing a new ignition system just because the old one had 'crap' parts on it was kinda stupid. Nothing wrong with the stock electronic ignition, 'crap' parts or not.
I'd be willing to bet the not starting issue lies right here.
twocents
Re: 73 Charger won’t run, any help appreciated [Re: cdwmotorsports] #2620290
02/12/19 03:34 PM
02/12/19 03:34 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Crap parts that have kept Mopars running for years?
Re: 73 Charger won’t run, any help appreciated [Re: stumpy] #2620328
02/12/19 05:11 PM
02/12/19 05:11 PM
Martinsville, IN
Martinsville, IN
twocents
Satilite73- I'm not sure what you're saying I removed a box coil and ballast resistor and replaced them with a box coil and ballast resistor.
I'm gonna go ahead and restate it since I'm pretty sure you didn't read it up top the starting issue is a ten year old problem not a new issue
Stumpy- I'm not opposed to those parts if they were original MoPar stuff but they aren't they are made by some no name company that had them made in some god forsaken country by cheap labor.
eBay-cdwmotorsports
Re: 73 Charger won’t run, any help appreciated [Re: cdwmotorsports] #2620351
02/12/19 05:45 PM
02/12/19 05:45 PM
SattyNoCar Offline
SattyNoCar  Offline
I understood what you said earlier just fine.
You're throwing new aftermarket parts at it in hopes of fixing a 10 yr old problem.
No sense putting new shiny aftermarket parts on it if you haven't fixed the original problem.
And stumpy is correct.
Good luck, I'm done.
Re: 73 Charger won’t run, any help appreciated [Re: cdwmotorsports] #2620356
02/12/19 05:47 PM
02/12/19 05:47 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Air, fuel, ignition, and compression, in the right amounts, at the right time. That is all that required for an engine to start and then run.
I'd try gas instead of carb cleaner. Fill the fuel bowls, pump the pedal, fire it up. It is starts, it will run until the bowl is sucked dry, which may be about a minute or less. If that happens, then clean the tank and fuel line and hook it up so it will pump fuel.
Re: 73 Charger won’t run, any help appreciated [Re: cdwmotorsports] #2620377
02/12/19 06:18 PM
02/12/19 06:18 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Why is the first thing people try to do is start a 50 year old car that has been sitting for 15? It got parked for a reason. IF this thing has been in the family why was it parked? Even if it starts now what? The tires are shot, the brakes are shot, every fluid that was in it is now CRAP. You can do more damage just seeing if it will fire than investigating problems and rooting out causes. Early 70s Charger will not start. OK. Put the car up on jack stands and get to work. ALL fluids need changed. The motor at least needs the VCs off and a little lookie liew. Seeing if the motor will crank is ok but like was said Yank the plugs out and give the cylinders a squirt of something slick. IF the motor turns over great then proceed to the basics. Suck, Squeeze, Bang, Blow. Do we have fuel at the carb? Yes Proceed to ignition. Pretty easy to check for spark in all the places it should be. GIven that it MIGHT start. Just take your time and stop throwing parts at it. IF your BIL is a clueless cheapskate then you are right there is NO TELLLING what he might have done.
Books are your friend. IF you are going to try fixing the car up over time buy you a Service Manual for your car (Amazon has them I am sure). It is the best money you will spend on any car that you are not familiar with.
Happy motoring.
Todd
Re: 73 Charger won’t run, any help appreciated [Re: TC@HP2] #2620485
02/12/19 09:02 PM
02/12/19 09:02 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
Hell starter fluid vs carb cleaner..... carb cleaner is not fuel...
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: 73 Charger won’t run, any help appreciated [Re: cdwmotorsports] #2620546
02/12/19 10:58 PM
02/12/19 10:58 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Did you already establish the timing chain was OK or not?
