440 rear main seal #2619575
02/10/19 11:04 PM
02/10/19 11:04 PM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
Hi. Does anyobody have an idea of how many hours it would take to install a 440 rear main seal on a 1970 B-body? Thanks.
Working on cars teaches you patience... and every curse word imaginable.
1970 Plymouth GTX -- A true gentleman's coupe, but a serious muscle machine.
Re: 440 rear main seal [Re: GTXKARL] #2619581
02/10/19 11:20 PM
02/10/19 11:20 PM
Ten times longer the first time than the tenth time wrench grin
AKA, the first time doing any thing automotive for a novice is always harder.
All the Mopar cars made since 1962 up to 1974 need to have the center steering link between the pitman arm and the idler arm removed to get the oil pan off, you will probably need to loosen up all the main caps to remove the upper seal also whiney
I would plan on 3 to 5 hours start to finish, maybe longer on the first time if you have all the tools you need shruggy twocents
Re: 440 rear main seal [Re: GTXKARL] #2619607
02/11/19 12:11 AM
02/11/19 12:11 AM
there has been some excellent threads on the caveats regarding this pesky situation (repeated leaks). See if you can retrieve em (I ain't up on it but see if you can) or someone might post a link to one or more of em. Good info was posted.
Re: 440 rear main seal [Re: GTXKARL] #2619639
02/11/19 01:19 AM
02/11/19 01:19 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Up on a lift wouldn't be bad. Flat on your back in the dirt is a little different. You can get it done either way, though. 3 to 5 hours is just about right.
Re: 440 rear main seal [Re: GTXKARL] #2619684
02/11/19 09:44 AM
02/11/19 09:44 AM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
Make sure you have all the required parts and gaskets before hand don't assume you can go to the parts house and they will have them on hand.
Re: 440 rear main seal [Re: bobby66] #2619755
02/11/19 01:06 PM
02/11/19 01:06 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Either way, allow time for a shower afterwards. Wear glasses or goggles and keep your mouth shut while under the engine. Dirty oil in your eye or mouth is no fun.
No matter how many times you have seen the nitro guys tear down a hot bottom end do not attempt this with a hot engine.
MOST importantly - DO NOT I repeat DO NOT let your wife catch you putting your oil soaked shirt in her new washer. Don't ask me how I know this.
Re: 440 rear main seal [Re: GTXKARL] #2619804
02/11/19 02:35 PM
02/11/19 02:35 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Rich H.
Esse Quam Videri
Re: 440 rear main seal [Re: ZIPPY] #2619812
02/11/19 02:49 PM
02/11/19 02:49 PM
moparx Offline
moparx  Offline
SUPER CHEAP way to keep junk out of your eyes and mouth, while also keeping said junk off your face. even if you toss it after the job is done.
pick one of these up before you start !
beer
Re: 440 rear main seal [Re: moparx] #2619829
02/11/19 03:16 PM
02/11/19 03:16 PM
I normally will let the car set over night or longer after draining the hot oil out of the motor before working on the opened bottom end up
I have had to remove more than one oil pan in the driveway on my back in the winter at night after work, no more tsk
Enclose shop now with a cement floor, nice creeper and heat boogie
Re: 440 rear main seal [Re: GTXKARL] #2619832
02/11/19 03:20 PM
02/11/19 03:20 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Rope seal or rubber seal?
