440 rear main seal
#2619575
02/10/19 11:04 PM
02/10/19 11:04 PM
Posts: 265 Philadelphia, PA
GTXKARL
Philadelphia, PA
Hi. Does anyobody have an idea of how many hours it would take to install a 440 rear main seal on a 1970 B-body? Thanks.
“Working on cars teaches you patience... and every curse word imaginable.”
1970 Plymouth GTX -- A true gentleman's coupe, but a serious muscle machine.
Re: 440 rear main seal
[Re: GTXKARL]
#2619607
02/11/19 12:11 AM
02/11/19 12:11 AM
RapidRobert
there has been some excellent threads on the caveats regarding this pesky situation (repeated leaks). See if you can retrieve em (I ain't up on it but see if you can) or someone might post a link to one or more of em. Good info was posted.
[Re: bobby66]
#2619755
02/11/19 01:06 PM
02/11/19 01:06 PM
Posts: 4,723 Moved to N.E. Tennessee
GomangoCuda
Up on a lift wouldn't be bad. Flat on your back in the dirt is a little different. You can get it done either way, though. 3 to 5 hours is just about right. Either way, allow time for a shower afterwards. Wear glasses or goggles and keep your mouth shut while under the engine. Dirty oil in your eye or mouth is no fun. No matter how many times you have seen the nitro guys tear down a hot bottom end do not attempt this with a hot engine. MOST importantly - DO NOT I repeat DO NOT let your wife catch you putting your oil soaked shirt in her new washer. Don't ask me how I know this.
[Re: moparx]
#2619829
02/11/19 03:16 PM
02/11/19 03:16 PM
Posts: 43,195 Bend,OR USA
Cab_Burge
I normally will let the car set over night or longer after draining the hot oil out of the motor before working on the opened bottom end I have had to remove more than one oil pan in the driveway on my back in the winter at night after work, no more Enclose shop now with a cement floor, nice creeper and heat
[Re: GTXKARL]
#2619832
02/11/19 03:20 PM
02/11/19 03:20 PM
Posts: 25,817 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Rope seal or rubber seal?
