matching a 67 data tag to a vehicle #2619248
02/10/19 12:06 AM
02/10/19 12:06 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
What numbers on the fender tag of a 67 vehicle match to the body ?
Re: matching a 67 data tag to a vehicle [Re: gtx6970] #2619258
02/10/19 12:45 AM
02/10/19 12:45 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The SO number.
Re: matching a 67 data tag to a vehicle [Re: gtx6970] #2619259
02/10/19 12:51 AM
02/10/19 12:51 AM
Cold Spring, NY
1970GTX Offline
1970GTX  Offline
Cold Spring, NY
The bottom right 8 digits on the fender tag match the last 8 on the radiator support stamping (scheduled production date mm/y space shipping order number).
The 2 digits before that match the 6th and 7th on the VIN tag(year and mfg plant).
On the bottom left, the 1st four characters match the first 4 on the VIN tag (car line, price class, body type)
Re: matching a 67 data tag to a vehicle [Re: 1970GTX] #2619431
02/10/19 04:31 PM
02/10/19 04:31 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
On a 67? I though only way to match fender tag with the SO number to the body was with broadcast sheet or window sticker. I also thought 67 was similar to 68 in that regard.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: matching a 67 data tag to a vehicle [Re: gtx6970] #2619489
02/10/19 06:37 PM
02/10/19 06:37 PM
Pasadena, Texas
fal3 Offline
fal3  Offline
Pasadena, Texas
'66 & '67 fender tags are unique. In '68 Chrysler changed the format of the fender tags.
Re: matching a 67 data tag to a vehicle [Re: RoadRunner] #2619500
02/10/19 06:55 PM
02/10/19 06:55 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The Shipping Order Number is on the fender tag, radiator support, and trunk lip. It can only be matched to the VIN with the Broadcast Sheet.
Re: matching a 67 data tag to a vehicle [Re: Jim_Lusk] #2619524
02/10/19 08:33 PM
02/10/19 08:33 PM
Maryland
ro23_j Offline
ro23_j  Offline
Maryland
The SO number can also be matched to the VIN on the IBM card.
Re: matching a 67 data tag to a vehicle [Re: gtx6970] #2619531
02/10/19 08:53 PM
02/10/19 08:53 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
The So number on the fender tag is the same number stamped in the rad support/ trunk lip ?
should match the lower right numbers on the tag ?
The car I'm looking at I think has its original owner card on the rad support. This card has both the vin and the So number on it correct ?
Reason Im asking is when I first asked about this car, the data tag didn't exist. Now all of a sudden it does. So just want to make sure its the correct one for the car
Sorry for all the questions, Im a rookie at the earlier cars
Re: matching a 67 data tag to a vehicle [Re: gtx6970] #2619773
02/11/19 01:36 PM
02/11/19 01:36 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
In short, SO number on body, SO number on buildsheet, SO number on fender tag, VIN on buildsheet, VIN on body VIN tag.
Re: matching a 67 data tag to a vehicle [Re: 6PakBee] #2619844
02/11/19 03:46 PM
02/11/19 03:46 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
and early cars are not as random as some would suggest
I've not previously seen the above two fender tags,
but they belong to:
RS23J77239xxx
RS23J77168xxx
