Re: Ported Apache or Thitek heads
[Re: biff426]
#2619387
02/10/19 03:04 PM
02/10/19 03:04 PM
Posts: 12,399 Taxes & Virus's R-US, NY
Dragula
Send them to Six-pack gut on here. He is super reasonable. He gets my vote at 373cfm at .600
[Re: biff426]
#2619688
02/11/19 10:06 AM
02/11/19 10:06 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
Frankenstein has some Thiteks on Ebay right now for 3k done ready to run just add valve gear.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: ric3xrt]
#2619691
02/11/19 10:18 AM
02/11/19 10:18 AM
Posts: 1,840 NW Indiana
fbs63
NW Indiana
The ones in the pic are machined for Jesel's rocker system. Unless it's just a representative pic.
[Re: biff426]
#2619694
02/11/19 10:47 AM
02/11/19 10:47 AM
ric3xrt
Trumbauersville PA
they just used a stock photo they have on their web page.
[Re: biff426]
#2620166
02/12/19 07:55 AM
02/12/19 07:55 AM
ric3xrt
Trumbauersville PA
not sure but I'm stuffing 2.20 in 4.06 bore 6.1 block right now.
[Re: biff426]
#2620169
02/12/19 08:13 AM
02/12/19 08:13 AM
ric3xrt
Trumbauersville PA
for sh!ts and giggles here's a 2.22 valve in a eagle head, should give you anIdea of what kind of room you have.
[Re: biff426]
#2620538
02/12/19 10:49 PM
02/12/19 10:49 PM
Posts: 936 Deland, Florida
biff426
Deland, Florida
I did some mock up with the apache heads and a stock bore 6.1 I have here and it looks like it will be fine. I bought the heads next question I have is the comfort level using a solid stem 2.18 with beehive springs. I am planning to spin this thing 7300-7600. I am a little concerned. I was thinking of buying the hollow stem 2.18 manley sells and replace the solid stem valves. What's everyone's thoughts?
[Re: biff426]
#2620668
02/13/19 05:43 AM
02/13/19 05:43 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I did some mock up with the apache heads and a stock bore 6.1 I have here and it looks like it will be fine. I bought the heads next question I have is the comfort level using a solid stem 2.18 with beehive springs. I am planning to spin this thing 7300-7600. I am a little concerned. I was thinking of buying the hollow stem 2.18 manley sells and replace the solid stem valves. What's everyone's thoughts? Sounds like $400 endeavor whether you change valves or springs. Except you may be able to sell the springs off your heads. I think it would be hard to sell the valves. One point would be, not sure you can fit dual springs on Frankenstein's setup.
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: biff426]
#2620891
02/13/19 06:29 PM
02/13/19 06:29 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Anyone know the minimum bore size for a 2.18 intake valve? Stock Apache on stock 5.7 bore no gasket.
[Re: MattW]
#2620961
02/13/19 09:27 PM
02/13/19 09:27 PM
Posts: 4,255 Canada
WO23Coronet
Canada
Anyone know the minimum bore size for a 2.18 intake valve? Stock Apache on stock 5.7 bore no gasket. How much radial clearance did the Apaches and stock 5.7 bore have?
[Re: WO23Coronet]
#2621172
02/14/19 10:25 AM
02/14/19 10:25 AM
MattW
Ontario Canada
Anyone know the minimum bore size for a 2.18 intake valve? Stock Apache on stock 5.7 bore no gasket. How much radial clearance did the Apaches and stock 5.7 bore have? No idea. IMO there is enough for it to open but add heat to it then Good news is that it opens away from the wall.
[Re: WO23Coronet]
#2621202
02/14/19 11:50 AM
02/14/19 11:50 AM
ric3xrt
Trumbauersville PA
3.917 bore it's about .060 for the 2.14, exhaust is about .010
I'll make it a point to get some photos up in the next week
[Re: biff426]
#2621203
02/14/19 11:52 AM
02/14/19 11:52 AM
ric3xrt
Trumbauersville PA
look into dual spring LS springs If you go hollow pm I'll buy the 2.18s you have also hit me up with a price on those apaches.
[Re: ric3xrt]
#2621501
02/15/19 12:57 AM
02/15/19 12:57 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
I could have them turned around in 2 weeks...just a thought. Brian
Brian Hafliger
